My brothers International with Ultrashift has about 500,000 miles on it and sometimes the ignition switch will not turn on the starter to crank the engine.
It only happens about once every 25 times you go to start the engine.
Wondering if this is a common problem? And if this is really the ignition switch or some other electronic issue....the N appears on the shifter like it is supposed to all the time, so it seems like it must be the ignition switch.
Should we just go ahead and replace the switch and see if that fixes it?
Thanks.
Ignition switch is failing, I think...
Discussion in 'International Forum' started by Pumpkin Oval Head, Oct 16, 2011.
