I ran a load in this morning and the blinkers were working when I left home and went to turn off the highway and I got nothing tried the hazards they didn't work either. got it home and went through the fuses and wiring and don't see nothing, could it be the signal lever switch? I've never had a problem with it cutting out or anything before it quit, any other ideas I've never conquered anything like this
Ih 9900i Blinkers/Hazards not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by IH9900, Apr 12, 2018.
Check the turn signal/flasher relay.
Heavyd Thanks this. -
Check fuse/breaker F2-D, should be 20 amp. This powers the flasher then it is straight to the signal stat.
spsauerland, SAR and IH9900 Thank this. -
interesting I don't think I pulled that one I checked all the other breaker ones and not sure how to check relays, I better go check that fuse before I buy this new turn signal switch lever I ordered
Thanks a lot that was the problem I thought I checked them all but that was the problem mine had a 25 amp one in it I didn't have the right one but I stuck a smaller automotive one in to try and it works now i'll get the right one tomorrow
