Ihc 9400 1995 cummins n14
Discussion in 'Ask An Owner Operator' started by Kwtrucker10, May 21, 2018.
  1. Kwtrucker10
    Kwtrucker10 Bobtail Member
    21
    hello all
    I just recently got ahold of a 1995 international 9400. It has a Cummins N-14 celect 370 hp 1400 torque engine. The problem i have is it has a 9 speed eaton fuller transmission. The rear axle ratio is 4.44 (spicer j400s). The truck wants to cruise around 1500 rpm at 45 mph. (1750 rpm = 55 mph/ 1900 rpm = 60 mph (top speed). I want to make this truck a 65-70 mph truck. I am not sure if i change the rear ratio to a 3.54 of how much of a dog it will be, or what transmission should i change it to? I have a very good feeling that this is a 9 speed direct transmission but i have not been able to get under neath it to check for certain yet. I have read about how some guys used to run double or triple over 13 speeds with very high number rear gears and still accomplish what i am hoping to achieve
    Thank you for any and all advice
    I know it was alot to read but i knew i needed all the information out there
  3. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    That's a very unusual combination. Road tractors rarely have that low of a gearing, if you are saying that your ratio of the rears is .444.
    The first thing I would ask you is are the rears that are in there in good shape? Would you rely on them for the next however many years?
    The next thing that I would suggest his get under the truck and see if that is an overdrive transmission or not.
    If it were me and your engine is only 370 horsepower and the rears are good I would probably check with Eaton to see if you can buy a double Overdrive transmission if that would gear you high enough.
    The reason I would concentrate on changing the transmission is because if the truck is geared that low you probably will be able to pull really well with the lower horsepower. But you need the overdrives to be at the right speed in the right RPMs.
    The road Rangers site has a calculator that helps you to figure gearing and overdrive with Road speed and RPMs.
    There also are formulas online they will show you how to figure that for yourself with your tire size and Revolutions, etc.
    The only thing is if you trade your transmission for a double overdrive I don't know what kind of a credit they will give you because you're not changing transmission like-for-like.
    But I would call them I'm sure that they can help you to figure things out etc etc
    Some other guys might have a different idea about it but if I had a truck that was geared that low I would enjoy the low gearing and being able to be geared low in reverse and have a low gear to pull out in, as long as I could cruise at the right RPMs. And given that your motor has less horsepower I think if you swap the rears you would feel that it would be more sluggish.
    That's the way I see things anyway.
    Kwtrucker10 Thanks this.
  4. Dino soar
    4,791
    26,878
    Dec 8, 2017
    And just on another note. I knew a guy many years ago that had a tri-axle dump truck that was geared incredibly low. He only had a 270 or 290 Cummins in it.
    He put at least a double overdrive Transmission in there and wow that truck would fly wayyy past the speed limit and Beyond. It surprised me. I think I was doing about 90 when I realized I was actually doing 90 and slowed it right down. I thought that was a good move he did.
    Just like you were saying that truck in particular would really only roll around 50 or 60 miles an hour flat out wide open.
  5. Kwtrucker10
    21
    Would it be in my best interest to find a 13 speed that has a double overdrive set up ( you know, top gear against the dash)?
  6. Dino soar
    4,791
    26,878
    Dec 8, 2017
    His was a 13 speed with at least double Overdrive.
    But you would have to call eaton and discuss all that with them. There probably is a particular model of a 13 speed, but there's probably a certain model that the steps and the ratios are better suited for your particular engine and horsepower and torque.
    That's what the ABC designation is after your transmission numbers. For example RTX 14610 C. The c gives you different steps than the a or the b.
    But if you call Eaton I'm sure they'll be able to help you get the right specifications and configure the right transmission for you.
    They should be able to give you all of the technical help that you need.
  7. Kwtrucker10
    21
    Understood that. Just need to get this truck moving soon and actually making money rather than sitting in my driveway. I’ll call Eaton tomorrow. They’re not too far from me here in Michigan
  8. Dino soar
    4,791
    26,878
    Dec 8, 2017
    Cool.
    Just watch you don't get any speeding tickets, LOL
    Good luck buddy
  9. Kwtrucker10
    21
    I am that young guy that loves a fast truck Choo choo haha. Thank you very much for the advice though!
  10. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    On same page with think it is dino soar. Also you may want to check out putting what most call "a back half" on transmission. Its going to make a 13sp out of the 9 speed. Most transmission shops can do this. Its not a cheap add on it is what a 13 is like from factory. The back half makes your 9 sp slightly longer so they will shorten driveshaft, and put new shifter knob in cab as now will be a splitter on it. I did it to a 1981 cabover i had. Made a truck out of it. Right now i have a 10 sp in a 01 379 and shop told me can't do back half on this 10sp as its a metric eaton. Cleaned off id tag. Yup its eaton 10sp made in France. Why people buy or order a semi trk with 9&10 speeds ? Been thinking of putting a 13 in my trk now.
  11. Kwtrucker10
    21
    I have the feeling like if I can get ahold of an rtoo 14613 this truck would be a whole different animal
