I'm looking for a portable a/c unit I can plug into my truck.
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Wehosh, Sep 21, 2023.
  1. Wehosh
    Wehosh Bobtail Member
    Sep 20, 2023
    A/C more often than not doesnt work, Windows are required to up at all times due to coal dust in the area. So I'd like to put a small a/c unit in my truck. I use to have one years ago, but I couldn't remember the brand. Any good recommendations or suggestions?
  3. tscottme
    tscottme Road Train Member
    They don't work very well since they have the hot parts too close to the cold parts inside a small case and they have little airflow. ANY small window unit will be MUCH more effective and use half of the electrical power. There are drivers that have a plywood board they put in the passanger side window once they get parked and keep the cab/sleeper cool.
    This is what it looks like after they get parked, not while they drive.
    https://external-content.duckduckgo...a597e88a485111999a6e4374558988ac79&ipo=images
    Chinatown Thanks this.
  4. Coolbreezin
    Coolbreezin Medium Load Member
    403
    422
    Jun 11, 2016
    Florida
    Really comes down to how much you want to spend. A lot of drivers are putting 120v mini splits in their sleepers (home units).
    I've been doing extensive research recently and found that 12v cooling systems are far more efficient but haven't progressed as far as 120v systems (not so many options & prices are higher). 120v runs directly from the batteries via a 3000 watt inverter. 12v is the same but are designed to be used & charged by a .
    tscottme Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,584
    13,304
    Jul 6, 2009
    The small window ac's pull 800 watts peak. 300 watts continuous.
    A 1000 watt inverter should be just fine. Or get a generator.
  6. Coolbreezin
    403
    422
    Jun 11, 2016
    Florida
    Snowwy's info is correct with slight variances depending on the manufacturer. His/her info is based on a 5000 btu window unit.
    Consider getting a capacitor also, $20.
