Improving posture behind the wheel
Discussion in 'Questions From New Drivers' started by hoss7071, Apr 29, 2013.
  1. hoss7071
    hoss7071 Bobtail Member
    36
    17
    Apr 17, 2012
    Mobile, AL
    I just finished my 1st week with my trainer. Had a couple of hiccups, I stalled the truck out at a rest area. Later on, I lost my gears while learning a 9 speed but that all happened on my 1st day. We have a pretty easy route: Atlanta, GA to Miami, FL.
    Anyway, onto my actual issue. Can anyone recommend a seat cushion, or ways to improve your posture behind the wheel? Even though the truck has air ride seats, my butt and knees are KILLING me after about 4 hours. Stopping and walking around helps, but I am not going to make any money doing that once I am solo. Plus, my trainer thinks the same way and I don't want to piss him off by asking for a rest break. Being 6 ft 5 doesn't help much either. :biggrin_25511:
  3. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    When my body starts aching, I do a couple of things, providing that I cannot stop right away to stretch out. I will wait for a straight stretch of road with light, or no traffic, and basically stand up without leaving my seat area. I can still see out the windshield, and can steer, etc. Is it the absolute most safest thing? No, probably not, but it's not reckless or anything. Straightening my legs out helps aid the blood flow back to the butt and back.
    I also deep breathe, which seems to relax the tense muscles somewhat.
    After time, you'll get used to the long driving times, and hopefully won't be uncomfortable then.
    Maybe consider getting a dumb bell and park it next to the seat, when you get your own truck. Using the weight to exerise your body will also help in blood circulation.
    EDIT: Just to be clear, when I say stand up, I mean I place my feet on either side of the pedals, on the doghouse and on the door post, then lift my butt off the seat while I straighten my legs. So I'm still over the seat and holding the wheel. I'm not actually getting out of the seat and like, walking over by the stick shift or anything, lol. :)
    CenutryClass and truckon Thank this.
  4. Gasienica
    Gasienica Heavy Load Member
    924
    528
    Sep 7, 2011
    Sit straight, don't have seat layed back to much, don't hang over the wheel have your arm extended and your back against a straight seat. Your posture might even improve.
  5. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    i am 6 5 also
    i keep my seat all the way up and back straight
    works for me
    seat close to the wheel and as horizontal as wheel will go
    everyone needs to find a position that is comfortable for them
    when i was driving a KW 660 i couldnt see right out the ewindshield with seat too high
    my knees always hurt
    in this 700 it is just right
  6. Newdriver85
    Newdriver85 Light Load Member
    59
    24
    Mar 22, 2013
    Philadelphia pa
    Glad someone made a topic about this I'm a recent grad and I'm 6'6. This is something I've always wondered about. Not to change topic but for you to tall guys how is sleeping ?
  7. Vito
    Vito Heavy Load Member
    878
    950
    Jun 4, 2012
    North Carolina
    I don't know if it's just me, or others do this, but I recently discovered that one of the reasons I was getting a pain in the neck is because I had the bad habit of leaning forward when I was driving. I know that this is considered bad posture when standing, so I now consciously sit back and keep my head close to the head rest while driving.
    My arms used to get tired when I first started driving. I'd drive for 3-4 hours and they'd get a bit tired in my forearms. Now I can drive 7-8 hours straight and my arms don't get tired. You build up stamina just like any other activity. But while you are, you might try raising one arm directly above your head, straight up, like you are reaching for the ceiling. Do this one arm at a time, obviously, while you are driving. And STRETCH it out. You'd be surprised how well this helps.
    As for seat cushions, I'm a firm believer. I found one at Wally World for $20 and it really does help, not just my butt, but I don't get any back discomfort any longer. My brother bought me a "Drive" seat, one filled with gel, as a present. It worked really really well for the first week. Then it developed a leak and my butt got all wet. I haven't used it since. But I'm still thinking about writing the company about it to see if they could replace it.
  8. Big Don
    Big Don "Old Fart"
    17,996
    35,644
    Sep 8, 2007
    Utah's DIXIE!
    I'm betting you have already tried this, but change the seat position once in a while. Raise it, lower it, change the tilt, change the angle of the back rest. Change the lumbar support, if you have that available.
  9. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    You might wanna check out the auto dept at walmart.They have seat cushions.I imagine trk stops do too.But you being new,you're going to hurt for awhile,plan on a good 2 months.It just takes getting use to.
  10. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    While I'm not tall (5' 9"), my legs are short and I have a long torso.
    I've found that it is necessary to lower the seat so that my heels are firmly on the ground. I also spend about half the time leaning forward so my back is not against the back rest, with my butt out, so that I'm stretching my lower back. This helps a lot. Changing position frequently helps, just as it does with bicycle racers that use several positions for riding.
    VisionLogistics Thanks this.
  11. okiedokie
    okiedokie Road Train Member
    13,365
    104,132
    Jun 13, 2011
    PNWET
    2342899-205154-a-woman-holding-the-steering-wheel-of-a-car-with-one-hand-while-driving.jpg
    Not the way to drive.
