Improving ride on a single axle truck.
Discussion in 'Questions From New Drivers' started by pete349, May 10, 2016.
  1. pete349
    pete349 Bobtail Member
    11
    Feb 13, 2012
    Paradise, UT
    I have an 86 peterbilt 349 single axle (about 170 inch wheelbase ) that rides really rough. I know the shocks are probably shot. Can anyone tell me if there is something I can do to improve the ride besides new shocks? My father in law has a single axle cab over frightliner with about the same wheel base and it rides pretty nice. Thanks
  3. JReding
    JReding Road Train Member
    1,955
    3,504
    Sep 8, 2014
    Puyallup, WA
    Do you have air or spring ride?
    pete349 Thanks this.
  4. No Clutch
    No Clutch Bobtail Member
    42
    24
    Apr 15, 2016
    MERIDIAN, MS
    It's time for a suspension swap!
  5. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Replace the shocks, and try to find an salvaged air ride suspension
    pete349 and No Clutch Thank this.
  6. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    Put a 53 full of mattresses on it!!!
    (sorry, i had nothing of substance to offer)
  7. MACK E-6
    48,927
    226,805
    That, and how is the cab mounted?
    If the cab is rigid mounted, that alone will make a truck a beater.
    JReding, pete349 and ExOTR Thank this.
  8. pete349
    11
    Feb 13, 2012
    Paradise, UT
    It has the air Trac rear end. Is that the problem? What suspension would you recommend?
  9. pete349
    11
    Feb 13, 2012
    Paradise, UT
    It does have a cab mate
  10. pete349
    11
    Feb 13, 2012
    Paradise, UT
    It has the air trac
  11. MACK E-6
    48,927
    226,805
    Air ride suspension AND an air ride cab, and you're still dealing with a rough ride?
    Hmmm... I'd say start with replacing the shocks.
    Grijon, pete349 and ExOTR Thank this.
