In cab audio solutions & laptop stands
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by -MadMax-, Sep 22, 2012.
  1. -MadMax-
    -MadMax- Light Load Member
    248
    72
    Feb 29, 2012
    Pennsylvania
    Hi everyone
    I'm a bit short on time so forgive me if this post is a bit crazy.
    I drive a 2012 Volvo with a nice in dash head unit that reads 3.5mm and USB (FAT 32 format) for AUX audio, CD, and AM/FM radio. Also, weather.
    I also have a laptop that I use to play music. Right now, I'm running through one of those FM transmitter things. I am however, much unhappy with this setup. Static noise and other stations tend to over power my signal (from a mere few feet away) often and I'm constantly changing the output station only to face the same problem over and over.
    Now, the in dash unit DOES have the 3.5mm jack input BUT... when I plug the 3.5 out of the laptop into the 3.5 on the dash unit, there is that "hum" and a whining sound. I have dealt with this before and I believe I used a ground loop isolator. I will be picking up one of these today to see if this will solve my problem.
    However, if my truck goes in for repair and I'm put into an older truck like I have came from, there is no 3.5mm input jack on those old radios. SO, not wanting to spend $200 on one of those "job boxes" like used in construction by DeWalt,etc, I'm looking into building my OWN "portable" audio solution that could be moved from truck to truck.
    Then there is the question of powering the unit. Should/could I use a self contained power option, like deep cycle batt's or a marine battery? Then, what are the options in charging this battery? I have a standard AC battery charger. I'm aware that a solar panel(s) would also be an option. The internal battery would have to last like 10hrs a day between charges.
    Are there any options for a cigarette lighter charging system? Maybe a switch where I could run off of cig lighter/power out when possible and then to take the unit out into a field, run off of the internal battery configuration.
    This system needs only to amplify an external sound source coming into it. Whether it is laptop,mp3,iPhone, or guitar.
    It also has to get loud enough for me to hear over the road noise/windows rolled down. Though, the window noise won't be a problem much longer with winter coming haha.
    any thoughts or suggestions, ideas?
    Lets hear 'em.
  3. Cobra67y20
    Cobra67y20 Medium Load Member
    317
    139
    Jul 24, 2012
    Oviedo, Fl
    Deep cycle batteries last longer, they are use as back up power at many cellar tower sites. bit more expensive. As far as using solar, your wattage is crucial in charging the battery, you will need an inverter from your solar panel to run equipment. Unless some how you wire everything through the guts of your internal wiring then your alternator recharges your deep cell battery also.
    [h=1]How to calculate battery run-time[/h]
    Q = I*t
    where Q is the charge in coulombs, I is the current in amps and t is the time in seconds
    http://www.powerstream.com/battery-capacity-calculations.htm
    -MadMax- Thanks this.
  4. THEPRIZEFIGHTER
    THEPRIZEFIGHTER Light Load Member
    109
    55
    Nov 4, 2010
    Dayton, OH
    They make boxes like this already pre made. I don't think they have a battery in them you just plug them into your cig. lighter. There called slip seat boxes. You can also put your cb in them as well. I didi a quick Google search and found a bunch of them, here's a couple.
    These look nice but kinda pricey at $155-175
    http://www.slipseatcb.com/j_boxes_series.html
    Heres another, but its made from plastic. It's much cheaper though at $65
    http://www.pacetronics.com/prodpage...d=144&Group_Selected=358&product_Selected=839
  5. -MadMax-
    248
    72
    Feb 29, 2012
    Pennsylvania
    Those pricey boxes are what I have in mind.
    Something like that...
    I bought a "ground loop isolator" and it fixed the problems I was describing with running into the dash unit.
    This is good. This will buy me enough time (hopefully) to build my custom box the way I want to.
    I'll try to post some pictures if/when I do it.
    Thanx for the links~
  6. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Go to any pawn shop or music store. Buy a guitar amplifier. The will amplify your sound. Get an adapter to go from the 3.5mm into the amp. Portable solution, inexpensive and the sound quality will be very good. Bought a Marshall practice amp for $100 new. Had tremendous sound quality, was loud and super portable.
  7. -MadMax-
    248
    72
    Feb 29, 2012
    Pennsylvania
    excellent idea!
    I could kill 2 birds with 1 stone - guitar AND music. ha
    thanx
