in dire need of help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by louu481, Dec 21, 2013.
  1. louu481
    louu481 Bobtail Member
    I have a 2007 freightliner century and after numerous visits to shops in and around houston have come up with nothing. I have 821000 miles on it. I have a knocking sound under floorboard on driver side that I can feel when I go over bumps .the sound starts loud then lowers with only 3 to 5 knocks.It does it mainly while bobtailing . I dont feel it under a load unless I roll over a very big bump at an higher speed. Not sure if this has anything to do with it but when I hit my brakes hard I feel a thump at the end of my brake.also no wear in tires. And u bolts are in good shape. I really would appreciate some info. Thanks in advance
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    I have that on my argosy, on mine it's worn sway bar bushes/rubbers
  4. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Cab bushings and cab air ride "sway bar" bushings.
  5. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    Could be a small kia wedged in there.......
    ya never know !!
    :biggrin_2551:
    RustyChops41, Cetane+ and Skydivedavec Thank this.
  6. Cat sdp
    Cat sdp . .
    20,968
    73,048
    Apr 8, 2012
    Orion's Belt
    Check the cab shock bolts too......
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    well at least it does not sound like major engine damage. sorry I could not be more helpful.
  8. zenaddler
    zenaddler Light Load Member
    158
    130
    Nov 7, 2013
    I drive a 1999 FDL and it has done that for years. I will check out the anti sway bar bushings. If you get on empty at mm 63 55 south in ar it will bang for about 10 miles. Not so bad anywhere else.
  9. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I can't believe nobody could find such a simple problem :biggrin_2552:
    Sometimes the effort has to be made to jack up the truck, put the frame on stand and then shake everything down and even to take a prybar and start prying to find out hat is not supposed to be moving around.
  10. zenaddler
    158
    130
    Nov 7, 2013
    it is not my truck. They wont fix it unless I point to it.
  11. louu481
    Thx for the info. I hope thats the problem. One would wonder how the back of the cab would bang under drivers side floorboard. Tomorrow morning I'll let my mech take a look.
