In school. will be getting on the freeway :/
Discussion in 'Questions From New Drivers' started by Danny N Angel, Jul 18, 2017.
  1. Danny N Angel
    Danny N Angel Light Load Member
    158
    116
    Jul 1, 2017
    we went out on side roads taking LH turns. Next will be RH turns, then the freeway. I needed to get faster at the double shift. so what is scary is the braking, having to get 8 on the tack to come out of gear, raise RPM's then clutch and at the same time slide into another gear.
    To me braking to get 8 on the tack feels like I am slamming on my brakes. Then having to rev up just to stop is a mental fight... now doing this on 45 freeway in Houston???? While trying to slow down for an exit.... PLEASE don't hit me!!! I'm doing what I'm told to do.
    Could anyone share what they went through the first time they went out on the freeway?
  3. Danny N Angel
    158
    116
    Jul 1, 2017
    Also the reason I am double clutching is because 1) im told too... 2) because im told that is what I have to do to pass my CDL driving test... 3) im told coasting is against the law.
  4. Mortarmaggot
    Mortarmaggot Heavy Load Member
    723
    739
    Apr 13, 2017
    I just finished school and that sounds very different than what we were taught. We slowed from 65 to under 55 and dropped to 9th in the high end tack which allowed an easy slow to 50 as we hit the off ramp, then slowed easily and steadily to 35 and shifted to 8th. They insisted we stayed 50 or better on the highway and no darn early slowing and backing up traffic a half mile or so away from the off ramp.
    Danny N Angel Thanks this.
  5. Mortarmaggot
    723
    739
    Apr 13, 2017
    Yes, double clutching is required in schools and on the test where I am. It works and isn't hard once you get it down. You are hardly depressing the clutch, and once you get the rmps down, it will often shift without the clutch, (Floating gears), but still use it because it is required. The coasting is about having control of your vehicle. Coasting for more than 100 ft is an automatic failure on our test in NC.
  6. Jmans
    Jmans Light Load Member
    221
    121
    Sep 3, 2013
    Focus hard and take your time.
  7. VIDEODROME
    VIDEODROME Road Train Member
    1,487
    1,297
    Jun 7, 2007
    angola, in
    This is why we have automatics. I swear there are goofy standards for teaching this stuff and from my experience people don't teach downshifting and slowing down in a way that makes sense.
    It seems like there should be a way to train that includes slowing, clutching when you feel it start to lug, go to neutral, then rev and clutch to a gear matching matching that lower speed. Instead, we have beginners flustered because they are trained to clutch down every single gear without skipping.
    I should say I'm not an expert here as I drove automatics for a long time. I did do a refresher recently on a manual 10 with my current company and only then did that trainer talk me through skip shifting and I was able to go from 10 to 6.
    Sorry side rant, but I sympathize with the beginners trying to learn this. Good luck.
  8. Danny N Angel
    158
    116
    Jul 1, 2017
    We are taught to downshift 2 gears at a time or one....to downshift 2 gears we have to be at 8 on the tack before taking it out of gear. if we are down shifting one gear then it is 10 on the tack before taking the gear out. Now I have not been on the freeway....so they may give the same rules as @Mortarmaggot explained once we are on the freeway. we have been told that we should not be more than 5 miles under the speed limit....but I am so focused on the tack and the mirrors that I forget about actual speed. also so far I have only made it to 9 gear on a 10 speed manual.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,136
    Mar 5, 2016
    White County, Arkansas
    It's not that dramatic really.
    Come off your freeway speed of 65 or whatever in top gear, allow the rpm's to fall to around 1200, push clutch in but not all the way, just enough to break power loose from the drives, double tap your fuel pedal to raise your rpms just before taking the transmission into the next gear down.
    Power has to be maintained to the drives because coasting and not having it on the drives will cause you to lose control in bad ways. This is the state standard for passing CDL. Once you pass the CDL, you can do whatever you need to do with that tractor provided you do not allow it to get away from you.
    Learning something is always stressful. Here you are doing something that requires everything you have, both hands and both feet plus a mind that stays ahead of the problem.
    Imagine having to toss the downshifting and stopping for upshifting and accelerating at a moment's notice when the traffic light ahead says green.
    If anything, coming off the interstate only need to slow to a certain speed, you can do that rather easily. It's better to learn downshifting on a mountain upgrade because you have to. Than to try and learn it on a flat land.
    RedRover and Danny N Angel Thank this.
  10. Danny N Angel
    158
    116
    Jul 1, 2017
    what did you do to skip 4 gears? 10-6?
  11. RedRover
    RedRover Road Train Member
    1,791
    2,612
    Sep 10, 2016
    Corsicana, TX
    Are you driving a 10 speed? If so, here is a helpful tip to know your recovery speed for downshifting.
    Clutch and shift to neutral, brake down to 45 mph. 45 is 4 and 5. 4 plus 5 is? 9th gear.
    Same all the way down to 5th gear. 55 10, 45 9, 35 8, 25 7, 15 6, 5 and dime(10) is 5th gear... then 5mph and below should get you down to 4th gear which is a fine gear to start and finish in for coming to a stop.
    What I do and what the majority of drivers do once they have their cdl is called floating. I will usually clutch to neutral but then I rev and shift without clutching in one smooth motion. I did this when I took my cdl exam as well. You can even get it by your instructors. Just say "clutch shift" when you clutch to neutral and then say "clutch shift" when you float it in there. Nobody will know the difference.
    And don't get too flustered at being flustered by Houston. Almost a year in and I still refuse to take any load that has me going through Houston during the day. I hate that ####hole.
    VIDEODROME and Danny N Angel Thank this.
