It took nearly 3hrs to get washed after a load of palm oil... which solidifies as it cools. The wash worker told me that running the heat for a few hours prior to wash would save time... which makes sense to me and is easy enough to do. However, another driver told me that running heat on an empty tank can cause it to “warp”... is this true? Normal running temp is 170F, but it can get to 210F for short periods going uphill... is that hot enough to damage (warp?) a tank?
I’m new to tanker (food grade) and eager to learn some “tricks of the trade”...
In-transit Heat on MT Tank?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Southeast Trucker Mike, May 26, 2018.
I would't think so but i haven't worked with heated tankers much. To find out for sure give one of the tanker repair shops a call thy deal with things like this everyday. Stuart tank in Elkhorn WI. should be able to help. stuarttank.com
Southeast Trucker Mike Thanks this. -
look at the manufacturers plate on the side of the trailer, it will specify max operating temperature. We haul resin heated to 250+ regularly in an insulated 407ss and it doesnt warp anything.
WildTiger1990, ChicagoJohn and Southeast Trucker Mike Thank this. -
How hot is steam they put on the tank? 250? I know it depends on pressure
We preheat the trailers, the resin instantly sets up around 200-210.
kemosabi49 Thanks this. -
Southeast Trucker Mike and 77fib77 Thank this.
Just noticed this sticker on one of our newer the tanks the caution sticker
ChicagoJohn, Southeast Trucker Mike and 77fib77 Thank this.
