Incandescent to led on a 2003 peterbilt tractor
Discussion in 'Peterbilt Forum' started by Loaderlou, Feb 24, 2014.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    I have a peterbilt 2003 379, it came with incandescent lights. I'm hooked to a 2005 east dump trailer with led lights. I changed all my tractor lights to led, but had to add incandescents in the system in order for them to work. An led flasher didn't work so I used a standard flasher. Am I doing this right?
  3. petedog
    petedog Bobtail Member
    28
    6
    Jan 21, 2013
    yes i had to do the same, not enough power draw with LED to make flasher work
  4. Weylyn
    Weylyn Bobtail Member
    Jan 28, 2013
    I also have a 2003 379 Pete. I converted to LED last year on whole truck. This said, go by Pete and get the flasher for LED turn signals. Have not had a problem
    EverLuc Thanks this.
  5. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    When using the "LED flasher" make sure it has a good ground on the flasher itself or it will not work.
    EverLuc and wore out Thank this.
  6. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    You can also put resistors inline.
  7. Loaderlou
    342
    131
    Feb 24, 2014
    Hi guys and girls, thanks for the quick responses to my dilemma. I'll give them a try and let you know how I make out. Sorry for not getting back sooner, but we're in a state of emergency here on long island and the lower part of NY due to a lack of salt. Lots of hours. Thanks again.
  8. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Is the DOT allowing you to fill the box and go as they did many many years ago during a bad winter?
  9. Loaderlou
    342
    131
    Feb 24, 2014
    Hi bigguns, in NY we have divisible load permits of up to 120000 lbs. Our problem was crossing the Verrazano Bridge from Staten Island to all our contracted locations as the bridge has reduced its weight per vehicle to 80000 lbs. This was put into affect after the bridge collapse in Minnesota. Since we've been getting hammered with all this nasty non compliant Global Warming Climate Change crap, they are letting us run our permitted weight
  10. Loaderlou
    342
    131
    Feb 24, 2014
    Hi Paul, will the resistors last longer than installing incandescents in each headlight pod?
  11. 7.3 cowboy
    7.3 cowboy Light Load Member
    210
    59
    Mar 4, 2013
    I just went to my parts stor and bought a 352 I think it was electronic flasher and it works fine
