Independents....what do you do for permits(OD loads)
Discussion in 'Experienced Truckers' Advice' started by nikmirbre, Aug 16, 2021.
  1. nikmirbre
    nikmirbre Road Train Member
    5,436
    9,824
    Jul 27, 2011
    High Point NC
    This was the last step in the process. Now that im on my own I really didn't give it much thought. What do you guys do for permits? I know there are states like NC where I can call and order my own but sometimes thats not practical. I assume you sign up with a permit service like Comdata or West Coast permits and put some type of money to draw from each time you order permits?
    I mostly run on annuals(and of course ill order these for the states I run in the most), I have 5 or 6 annuals that are basically useless now Virginia being the only one im upset about having to re-order because it was $570. All the others were about $100
    Now that I have my own numbers can I sign up with each state to order online?
  3. skallagrime
    skallagrime Road Train Member
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Not on my own, but ive handled things just straight to the state using my company numbers as well as using west coast permits.
    It depends on what state and what commodity youre running, for the annuals, unless theyre just frustrating to deal with, may as well set up on your own. For everything else, i recommend wcs, not because itll be cheaper, its not, they do charge a chunk of change. (Not exhorbitant, but its an expense) but because of the lower hassle of only having to deal with 1 person back and forth
    nikmirbre Thanks this.
  4. Rontonio
    Rontonio Road Train Member
    6,319
    46,132
    Aug 9, 2009
    you should be able to go to each state website for oversize permits you run in. You will be able to open an account with each to order and pay for them with credit cards. It generally fairly straight forward to do this - the mapping programs will be the largest pain in the buttocks (some will require that you run internet explorer NEBRASKA ) and nothing else.
    you can then order states you don’t often run in through a permit service or open an account at that time. You will likely have to have your insurance guy send certificates to the states to open the accounts.
    Even the holdout states like Louisiana will allow you to purchase permits with a credit card now instead of an escrow account.
    I think I have log ins for about 25 states - if I can remember where I keep all the login credentials.
    you will save quite a bit of money doing your own and the turn around can be faster as you don’t wait in the permit companies que. this is especially true if you run heavy where the permit companies assess surcharges for superload permits that can be pretty steep - take Nebraska for example the permit is $25 for 200,000 lbs (10 axles at 20k per) but the permit company fees could be an additional $150.
    if you run California- order through a permit service (take my word for it)
    Oregon’s permitting will make you want to jump off a very tall cliff…
    good luck
    nikmirbre, kylefitzy and Cat sdp Thank this.
  5. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    I only run O/S in two States, NY & VT. I set up an on-line account in NY via OSCAR, this also covers IFTA & HUT. VT was the old paper application via snail mail. NY was $360 & VT was $112. Was quite simple actually, couldn't tell you about other States though..
  6. xsetra
    xsetra Road Train Member
    5,119
    6,998
    Aug 21, 2011
    As mentioned, set up your own accounts. Really is easy and you can save a lot of money doing it yourself.
    I think Ohio and Louisiana require a certificate of insurance on file.
    When I need a permit and don't have the time, I use Permit Wizard, Working with one company does make it much easier when ordering multiple permits.
    Good luck
  7. bonder45
    bonder45 Road Train Member
    1,803
    5,450
    Oct 2, 2011
    Williston, ND
    If you can add $25 / state to your invoice you can get a 3rd party to do it otherwise as other ma have said just do it yourself.
    It’s super easy
  8. nikmirbre
    5,436
    9,824
    Jul 27, 2011
    High Point NC
    Oh yeah id much rather do it myself. Thank you guys for your help! Im gonna work on getting it set up next week.
  9. nikmirbre
    5,436
    9,824
    Jul 27, 2011
    High Point NC
    I will never use WCS anymore. I had a 15 tall load that the receiver changed their mind about receiving about 2 years ago. So I had to turn around and take it back, called WCS and ordered permits. 1 permit in particular I knew was gonna take at least 4 days.....(Va Beach city permit) come to find out 5 days later, they didn't even put the order in for any of the permits!!
    clausland Thanks this.
  10. skallagrime
    3,856
    9,943
    Apr 10, 2012
    Indiana
    Ouch. Fair assessment, ive not been burned like that, sorry that happened
  11. clausland
    1,933
    11,067
    Dec 5, 2014
    North Woods
    I've found that it takes much longer to figure my routing that it did getting the permits..
