Info needed on a radio shop
Discussion in 'CB Radio Forum' started by stacks, Aug 27, 2025.
  1. stacks
    stacks Road Train Member
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    I’m not here to Bash this shop I’m just interested if f any drivers have had work done there as I’m
    Considering buying a radio from them
    Cool electronics Houston Texas
    I noticed three tech doing bench work on there website I couldn’t see any scope or diagnostic Equipment
  3. Ridgeline
    22,853
    126,503
    Buy a reasonable priced radio that has not been touched by anyone, install it in the truck and focus on the antenna system. The idea of buying one and having it tuned is the worst thing you can do, they are tuned at the factory but the antenna system matter a lot more.
    mike5511 Thanks this.
  4. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    Your misting my point I’m intending Buying a new radio and it would need to be modified for 11 meters I was simply Asking for reviews on that shop if anyone had bought or had work done
    cuzzin it Thanks this.
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,707
    1,274
    Jun 26, 2017
    Nebraska
    You have to admit your intentions on your first post wasn't real clear, since you were asking about the work they do. I'm sure that's why Ridge assumed you were thinking about doing an alignment on a new radio if you bought one from them.
    Most of these radios today are easy to modify, some you don't even take the covers off. The real question I've had for awhile is when a 10/12 meter radio is modified to use on the 11 meter band, does it really need an alignment done?
    Hopefully someone who has done business with this shop will eventually be able to answer your questions.
    stacks Thanks this.
  6. cuzzin it
    cuzzin it Road Train Member
    3,693
    13,682
    Jan 19, 2008
    Berea, KY
    My 2 cents is to buy an 11 meter radio. There are plenty to choose from.
    I've had radios tune and tweaked before.....
    For a small radio it worked well, with improved clarity. I also had it done on a 10 meter..... bad mistake......
    What really helps is antenna being right.
    stacks Thanks this.
  7. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    I’m well aware the Antenna is might make point being if the Average radio operator doesn’t have knowledge or tools a radio shop has to do the Alignment I’ve previously bought from Walcott radio with out any issues I’m also on there mailing list for special
    Offers and they have all the test equipment I’ve been into there store plenty
  8. Ridgeline
    22,853
    126,503
    This is why we all assumed you want the radio to be peaked and tuned, if it is a conversion, most of the time it doesn't need alignment.
    What radio are you looking at?
  9. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    Stryker 955 + I’ve been watching a few videos on you tube to modify the radio to work on the 11 meter Band it’s basically a wire that needs to be snipped i currently own a 955 V1 which I’ve owned since 2018 so I’m looking to Add Another radio and I really like the Stryker radios.
    High Stepper Thanks this.
  10. stacks
    1,552
    854
    Oct 27, 2011
    Emerald Isle
    My Bad I got wires crossed with a peak and tune and Alignment
  11. cuzzin it
    3,693
    13,682
    Jan 19, 2008
    Berea, KY
