Injector spill vave
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by javelinjeff, Apr 1, 2018.
  1. javelinjeff
    javelinjeff Medium Load Member
    621
    185
    Aug 30, 2007
    victorville,ca
    2013 KW T-660 with ISX15 400ST. Getting an Injector Spill Valve fault on dash display and yellow check engine light. Codes from my KR Scanguage are as follows,, ID 656 FM 7 CNT1. Cleared codes but still remains,no noticable change in performance, checked for fuel in oil, none found. No loss of coolant. Assume the engine is a CM2250,,Anybody familiar with this issue?
  3. pushbroom
    pushbroom Road Train Member
    1,780
    7,319
    Sep 1, 2012
    Code pulls up for injector #6 mechanical system not responding.
    Most times it is a failed injector. Check for coolant in the fuel as well. The injector cup o-rings can leak coolant into the fuel and if let go for long enough will start to take out injectors. There is a repair to press a ring into the injector cup to help seal it back up.
    spsauerland and javelinjeff Thank this.
  4. javelinjeff
    621
    185
    Aug 30, 2007
    victorville,ca
    Code went away, I put some fuel additive in and about 200 miles later code cleared itself,,we will see what happens tomorrow
  5. Rounded_nut
    Rounded_nut Light Load Member
    92
    107
    Feb 25, 2018
    You'll be replacing it soon enough, I had a similar situation, error came and went, finally wouldn't go away.
