Injectors!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by haulhand, May 10, 2012.
  1. haulhand
    haulhand Road Train Member
    Woohoo I get to buy a set of injectors tomorrow for this ###### old N14. Oh well owned the truck for a year and this is the first problem.
    - Sent from my iPhone using Tapatalk
  3. seabring
    seabring Road Train Member
    1,844
    1,882
    Apr 24, 2011
    How much is this going to cost? How did you know that you needed to replace the injectors?
  4. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    I've replace injectors on my n14 1 at a time as they went bad. 6th 3 yrs ago and 1st 2 yrs ago.
    I do them myself and its prtty easy
  5. haulhand
    The truck has a horrible miss when you throttle into it. It also has a wicked pop when it idles, and it's blowing raw fuel out of the stacks. The set including labor is going to be 3600 the cummins dealer wanted 6 grand and couldn't do it until Monday.
  6. haulhand
    I think the other 5 are pretty weak so I'm going to just put a set in it.
  7. crazzy448
    crazzy448 Light Load Member
    86
    6
    May 3, 2009
    panhandle wva
    Cummins has a deal if you buy 5 you get the 6th free. just installed a set last week in a cabover for a customer.
  8. rebeloutlaw66
    rebeloutlaw66 Light Load Member
    199
    41
    Sep 2, 2009
    I'm glad this post came up because I'm about to replace an injector in my m11 and I am wondering after I remove the shaft will the injector be easy to remove or do I need a special tool to get it out of the hole? Any help would be much appreciated because I sure don't want to break something else!
  9. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Rebel, a manual for your m11 is a very valuable tool. It will give specs and show how to do it. You have to set the torque values throughout as you install. At least on my n14.
    Ps. We were getting reman rx injectors for around $250 from volvo. No core as i had purchased a few from craigslist. Guys at our yard change injectors one a year. In 6 years he has a new set. Says it cushions the blow a little.
    An overhead should be included at that price.
  10. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Was just looking at a truck with an N14 in it. Local cummins shop quoted me $530 a piece for injectors.
  11. ohio_redneck75
    ohio_redneck75 Light Load Member
    128
    51
    Sep 27, 2010
    coshocton,ohio
    i had 2400 in injectors for my old n14 they where not oem but aftermarket brand
