Hello everybody,
I have this crazy idea about living in a semi trailer. I know that race drivers, etc will do it to support their mobile lifestyle, but I want to do it also if I end up in the career I want, which will involve me moving around a lot.
Essentially, what I want to do is finish and furnish a 53' trailer like an apartment inside, and live in it. Yes, there are a lot of issues with this. I am hoping for some advice from truckers on how to approach these problems. Here are my questions, below. If you have any other comments or advice, I'd love to hear it.
How can I move it? I don't have or plan to get a truck or Class A license. Is it possible to put out an ad somewhere (where?) to have a trailer moved from A to B? Is this something an O/O would be up for privately, or do I need to go through some sort of agency? What could I expect to pay per mile?
Where can I park it? So far my thoughts have been trailer or RV parks. After all, they're full of trailer homes (albeit of a different sort). I'd want to be staying in once place for 6 weeks-6 months. If you're familiar with living trailer parks, do you think that most or many parks would be OK with having a semi trailer in their park rather than a mobile home or RV?
What regulatory/legal issues might I run into? How do I keep a trailer registered? Will this be difficult, as a private individual?
When I'm modifying the trailer to make it habitable, what sort of things do I need to keep in mind to keep the trailer roadworthy? (Adding say vents on top, or plumbing underneath...
Any other advice or insight into this idea is fully welcome. I'm not sure yet whether the response will be "You're crazy" or "Yeah, people already do this and it's not that bad".
Thanks!
Edit: I neglected the main reason why I'm considering a semi-trailer over a purpose-built mobile dwelling. This idea started out as an option to have a mobile workshop wherever I moved, with a mill, lathe, welder, etc... then the idea evolved into living in the trailer. I can't put shop equipment in an RV.
Input needed on crazy idea - trailer apartment
Discussion in 'Questions To Truckers From The General Public' started by Ned, Jan 29, 2010.
Page 1 of 7
Being lazy, I wouldn't bother. For the amount of time and money you would have to invest, you'd be better off with a large RV (like a Bounder, or something similar). Easier to move around (relatively speaking), and in the long run probably cheaper and more comfortable. Basic van trailers really don't lend themselves well to long term living facilities without massive amounts of upgrades in insulation, and setting up wiring and plumbing is gonna be a stone bear of a project. I'd rather spend the money on a larger RV, and get the appropriate licensing and training in its operation. But again, I'm lazy.
LavenderTrucker, Texas-Nana, SweetSouthernRide and 3 others Thank this. -
Thanks for your input, brsims. For me, the conversion project is half of the draw of wanting to do it. I love building stuff, and all the wiring, plumbing, insulation, drywalling, etc will be fun. An RV does offer a lot of cool advantages, but I neglected the main reason why I'm considering a semi-trailer over a purpose-built mobile dwelling. This idea started out as an option to have a mobile workshop wherever I moved, with a mill, lathe, welder, etc... then the idea evolved into living in the trailer. I can't put shop equipment in an RV.
of course you can. look at toy haulers or job site haulers. They contain living quarters plus vehicle storare or the shop for whatever type of busines/work the crew does.
Look, you're going to ram up against a lot of different problems.....first off is the DOT. And frankly I keep seeing some trailer version of 1973 Hippie School bus conversion. If you don't want an RV then look at trailer rvs that can be towed with a pickup or car. If you're determined to do some kind of remodeling then remodel a trailer rv. You'll be staying within the legalities of the vehicle and thus be able to park it in rv parks and mobile home parks.LavenderTrucker, simplyred1962, Hedon and 1 other person Thank this. -
Get you a nice RV and pull you a modest trailer behind it with all the machine shop equipment. You can go just about anywhere, and unhook when necessary.
LavenderTrucker Thanks this. -
Nana's idea of a toy hauler is best . It could be pulled with a medium duty truck . The total weight would have to be watched though . Too much weight in the rear could cause handling problems .
A toy hauler would also allow ground level entry rather than dock height although an old HHG trailer would also allow that .Working Class Patriot, LavenderTrucker and Bogey Thank this. -
Contact some RV dealers and see if they have or know where a large tow behind travel trailer is that got jackknifed or wrecked some how.You might be able to find one cheap.Just rip all the guts out and put them in the dry van or a old furnature moving van(lower deck and side door for people).
That's not a bad idea, Freighttrain. I've been planning on just installing whatever furniture and appliances I can find that are appropriate. I doubt this would be cheaper, but probably better...
Does anyone have any insight on moving or parking a personal live-in trailer? If you're an O/O, is this something you would do? -
Ned, I can see you have your heart set on doing this. But keep in mind the problems you may be creating for yourself. Not just for the moving of it, but for the parking of it. I think you will have a hard time finding an RV park that will let you park there.
Also, when you realistically look at what it is going to take to plumb it for sewer, grey water and fresh water, to insulate it, to heat and cool it, I think you will find that it is cost prohibitive. Can it be done? Of course it can, if you want to spend the money. But will it be logical? I don't think so, but that is just my opinion.
Somebody posted on here doing the motor home with a trailer. Not a bad idea, and probably could be had for less money than what you are looking at overall on a big truck.
Of course if your heart and mind are really set on doing this, then go for it.LavenderTrucker Thanks this. -
I have a feeling if he builds this that I will see it on a T.V. show on CMT sometime in the near future....
Working Class Patriot Thanks this.
Page 1 of 7
