Anyone,
I've recently purchased a new 2013 388 Peterbilt. I'm trying to pull a spread axle trailer. I would like to install an electric switch that will dump the air pressure off of the front spread axle on the trailer.
Can anyone suggest what wires to use under the dash? I've been told that there should be some wires that go to the second trailer jack on the rear of the tractor....and that I should use the largest pin from that jack....I would like to install an oem switch if that is the best route to go? Any ideas or suggestions??
Installation advise for Air dump switch for 388 Peterbilt
Discussion in 'Peterbilt Forum' started by Dman_68, Feb 8, 2014.
This is similar to my question about the yellow wire http://www.thetruckersreport.com/tr...ed-trucking-forum/240862-the-yellow-wire.html.
First off, is your trailer equipped with a dump valve already? If so how is your trailer wired. The key is finding out what wire on the trailer connection controls the dump. In most cases you will need a duel pigtail set up.
If your tractor already has the second cable set up you might be able to put a switch on one of those wires and wire the dump valve to that on the trailer side. You need to some how disable your abs on that axle though when its dumped. (might be why tmc uses the yellow wire for abs) If you dont, the abs will go nuts trying to brake a wheels thats not firmly planted.Dman_68 Thanks this. -
Id recommend putting the dump on the rear axle. Not the front. The whole idea of a dump valve on a spread is to get eight of that back axle so you can hit a dock, or tight parking spot. And for very tight turns. If you've got a big heavy load centered on that trailer, and you dump the front axle, the frame is just going to sag and put weight on those tires anyway. It's just too far off a bridge to gap with 45 thousand pounds. Put it on the back axle and it's only a ten foot over hang, much less stress on the frame.
Thanks!
Yes, the trailer does have a dump value already in place and the tractor has a dual pigtail as well. I believe the pin I need is the large center pin, in the seven pin connector. I just can't see where all those wires lead to from the pigtail on the tractor. If I can locate those wires, I'm sure it will be no big deal to place a switch. However, I did locate a lot of wire under the dash....not sure if these head to the pigtail or not? Any ideas?
thanks! -
thanks! -
If its not hot to start, its a bit harder. You need to find where that wire goes and add a fused circuit to make it hot. also need to add a switch.
You coudl use relays instead of switches, but if your fuse box is near where you want the switch, you could just put a switch inline. -
Do you know if its the green or yellow pigtail that controls the dump?
