installing a pusher axle under a 98 ch
Discussion in 'Mack Forum' started by Dwightsch, Apr 17, 2015.
  1. Dwightsch
    Dwightsch Bobtail Member
    14
    im instaling a steerable pusher just need to know where to tie the brakes in at
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    Service brakes only correct? The tandem drive axles already operate off the primary tank. The steer axle service brakes and trailer operate off the secondary. The trailer has its own storage tanks and does not technically operate from the truck storage tank is just fed from it. I would connect a 5/8 line from the secondary tank to the control valve supply port, valve center of crossmember or frame mounted. Tee the control line to the other drive axle service valve control line.
    Dwightsch Thanks this.
