Installing C.B. in 9400 International
Discussion in 'CB Radio Forum' started by bulldozerbert, Apr 9, 2009.
  1. bulldozerbert
    bulldozerbert Medium Load Member
    622
    240
    Oct 5, 2008
    Ontario
    We got a 2003 International 9400 at work. I was going to install a c.b. in it today.
    First problem is: of all the c.b.'s I have (three) none of them fit in the hole. I took off the faceplate that is where the radio is to go, but they are all too big. Do I need to buy another radio that fits, or can you buy different sized faceplates?
    Also the wire plugs that are there ( for the power) I presume, are not the same as the radio's I have. So, do all the different kinds of radio's have there own style of power plugs? (I would have thought they may be all the same)
  3. arky870
    arky870 Light Load Member
    98
    26
    Nov 5, 2008
    moulton,al
    are you talking a cb or fm radio?it says cb but sounmds like you mean a fm.
  4. bulldozerbert
    622
    240
    Oct 5, 2008
    Ontario
    I mean cb radio. There is a spot in the overhead dash for a cb, in the 9400.
  5. joey83854
    joey83854 Bobtail Member
    33
    5
    Mar 1, 2009
    post falls id.
    I took the old faceplate off and made a new faceplate out of a piece of aluminum made to the correct size of the radio I had. Looks as good as factory!
  6. bulldozerbert
    622
    240
    Oct 5, 2008
    Ontario
    I got the radio installed today. I had to take off a plastic spacer with the hack saw to make room for the radio I had, but it is all inside, so no one will ever know.:biggrin_25525:
