I've got 4 inch round LED's I want put on the back of the sleeper. Any suggestions on brand/type of hole saw to use? Tips on cutting?
Installing lights behind the sleeper
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mighty1, Mar 19, 2018.
I dunno if they make a 4" knockout punch. Probably expensive if they do but it would sure make a clean hole without possibly damaging surrounding sheet metal/paint.
Mighty1 Thanks this. -
Quick Google search shows Greenlee makes a 4" knockout punch for a little under $200. Greenlee's are good tools but you can probably find something from harbor freight maybe for a lot cheaper if you don't want to spend a lot.
Well you need 4 1/16 or so hole saw that or you need a diegrinder to ream it out a littleMighty1 Thanks this.
10-4
10-4, I've got a die grinder handy.
I did find a set from Milwaukee tools with 22 pieces, but I don't know how often I'm going to use a hole saw of any kind
Knockout punch is a lot cleaner. I wouldn't use a hole saw. After removing sleeper interior you pop a small guidehole in it with about a 5/16 or so drill bit. Then screw the halves of the knockout punch together and tighten with wrenches until it cuts out the hole. You won't scratch anything or bend any sheet metal oil panning it or anything like that.
snowman_w900 and Mighty1 Thank this. -
Big 10-4
Didn't know this tool even existed, thanks.
