Installing locking differential into truck and need to cut part of the diff to clear!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JamesMc84, Nov 5, 2020.
  1. JamesMc84
    JamesMc84 Bobtail Member
    43
    Mar 20, 2017
    i attached a picture. What is the best way to cut this out? What tool/s should I use?
  3. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,384
    Jul 12, 2017
    No, no and even more no.
    Never had to cut a housing to install a diff. Somethings not right.......
    Itsbrokeagain and Klleetrucking Thank this.
  4. lester
    2,821
    7,487
    Jan 2, 2012
    NW, Iowa
    @Goodysnap i installed a locking diff in my rear axle, did not have one before and I had to clearance the housing just like he show in the picture. Would not have been able to get the center section in without doing so. I can't remember but might have even needed the clearance to operate. The extra room was for the sliding locker gear or whatever you would call that.
    I used a grinder, took me probably an hour. Guess I could have used the torch
    spsauerland and Goodysnap Thank this.
  5. lester
    2,821
    7,487
    Jan 2, 2012
    NW, Iowa
    Screenshot_20201105-032857_Chrome.jpg to get that slider to clear is why it needs cut out. @Goodysnap my locker seems to be not functioning exactly right, acts like the gears are not fully engaging and I can feel it lock and then slip and lock again. Its only about a year old and I've tried to be easy on it when using. Only in low traction situations. Any ideas?
    Goodysnap Thanks this.
  6. Goodysnap
    3,502
    8,384
    Jul 12, 2017
    Ahhh.....Never would of thought of that.
    More clarification from the OP would have made that much easier to understand if thats the case.
    If he needs to ask how to do it. He probably shouldnt be.......
    wore out and spsauerland Thank this.
  7. Goodysnap
    3,502
    8,384
    Jul 12, 2017
    I would check air pressure to the cylinder. Sound like the dogs on the collars are rounded off ?
    wore out, spsauerland and lester Thank this.
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,879
    May 31, 2010
    West Harrison, In
    First check would put pressure gauge teed @ locker cylinder and see if getting full air.
    lester and Goodysnap Thank this.
  9. JamesMc84
    43
    Mar 20, 2017
    It’s a locking diff that this truck never had. It’s required to get it in
  10. JamesMc84
    43
    Mar 20, 2017
    I was thinking a grinder. Just wanted to see if anyone that has done it before had any suggestions
