installing some type of pump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by snowwy, Feb 19, 2012.
  1. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    anyone ever done? what type did you install. and what's the cost? and added weight?
    i'm thinking of installing a pump of some type to my truck to pump rail cars into the tank instead of packing around a pump on the catwalk.
    it's too heavy and there usually isn't two guys to help.
  3. wis bang
    wis bang Road Train Member
    3,381
    3,972
    Jan 12, 2011
    Levittown, PA
    Ranger pump. 100,000 ways to mount, PTO driven. They are a copy of the old Roper pump.
  4. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    I used to run a three inch roper, for pumping asphalt and other petroleum products. It ran off of the PTO and I had it mounted to the frame. Before you buy a pump you need to know exactly what you are going to be pumping with it so that you can get a pump that is compatible with the products that you are going to be pumping.
