instrument cluster on volvo 2007
Discussion in 'Volvo Forum' started by salim patel, Nov 15, 2015.
  1. salim patel
    salim patel Bobtail Member
    40
    6
    Nov 15, 2015
    clusters lights goes on and of while diving also when lights goes off the vollts num goes up to 20v cheak the voltage at alternaor ad its good14.5 or so should i look for new cluster or look for loos wire allso when i bang on the deshboard the lights comes bake on volts goes back to normal then sometims it shows 16 or 17 volts any help would be appricated tks
  3. Neilwhayes
    Neilwhayes Bobtail Member
    30
    25
    Jul 8, 2014
    miramichi nb. canada
    Had the exact same problem on my 07, high volts,lights would go out. bang the cluster would be back to normal for a while. tried everything, eventually changed cluster 2 years ago now, no more problems.
  4. X mech
    X mech Light Load Member
    64
    22
    Nov 14, 2015
    I have disassembled these clusters and removed printed circuit boards. held up to a lamp and repaired them by soldering telephone wire between burnt out circuits. There were more burnt circuits than dash lamps Then check connections for tightness.
  5. salim patel
    40
    6
    Nov 15, 2015
    thank you very much guys i will look around to see if i can repair my cluster because new one is quite expensive
  6. Fidus
    Fidus Bobtail Member
    18
    4
    Jun 17, 2016
    Franklin Park, IL
    Have thesame probelm i drive with a rubber hammer next to me to fix the probalem. Let me know what worked for you if you ever get it fixed. These clusters are super expensive and hopefuly theres a cheap fix.
