What controls the brightness of the instrument lights? Mine do not work at all (maybe a rheostat turned to off). The circuit breaker is good.
'05 T2000
interior instrument lights do not illuminate
Discussion in 'Kenworth Forum' started by chevyman486, Jul 28, 2013.
There should be a dimmer switch. Not sure of the location on a T2.
I have pushed, pulled, turned, yanked, twisted, and flipped every knob in the cab. Still no lights. I'm sure it has a rheostat but unless it is under the hood I can't find it.
Check your fuse box, maybe the fuse for the lights blew. If not, maybe there is a loose wire behind dash.
Check the manual and see if it shows location of dimmer.
My Pete has a knob on dash.
My Toyota has the edge of a wheel that protrudes from the dash that controls brightness.
You might have an up/down button.
I have not operated a kw. -
my 06 w900 has a roll wheel to adjust the brightness. its down on the left side of the steering column.
I found it !!!!! Its on the right side of steering column next to wiper control. It looks like a windshield with a light bulb inside of knob. Man at the rate im going in the next 15 or 20 years Ill be the man to come to for all your T2000 questions. LOL. Thanks to everyone for your thoughts.
