Intermitent shut down issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cgtransport, Sep 21, 2012.
  1. cgtransport
    cgtransport Bobtail Member
    While driving down the road the truck will shut down for approximately two seconds. Check engine light and shut down light will come on for about two seconds also but no buzzer. Tach will drop down to around 1300 rpm. Lose about a mph or two. Feels almost like you bumped the key for a second and right back on. Road conditions or anything else does not seem to make a difference. Doesn't happen very often. I had the computers scanned/checked and no codes out of the ordinary. Could this be fuel delivery or throttle positioning switch??? Very intermittent...hard to fix when it ain't broke.
    Anyone else experience this issue?
    Truck is a 2001 FLD Freighliner with a 60 series detroit. Bone stock.
    Thanks in advance
  3. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    If no codes, something is causing a shut down. Have someone scan the computer to see what caused the shut down.
  4. Cobra67y20
    Cobra67y20 Medium Load Member
    317
    139
    Jul 24, 2012
    Oviedo, Fl
    Sometimes the micro processor or the software to run the mini computer will have a glitch. May have to be reprogrammed or new hardware.
  5. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    I would guess that you're losing ignition power and the check lamps are coming on the same as if you just turn the key on without the engine running. I would look at the breakers and relays and feel for a hot one.
    Could also have a hot wire intermittently shorting to ground, common at the starter connections.
  6. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    start looking for bad wiring someplace. Check your grounds too.
  7. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Agreed. Start in the battery box and work your way forward.
  8. Jorihe84
    Jorihe84 Road Train Member
    2,763
    1,333
    Sep 1, 2010
    North Florida
    Happened to me once. Shop said it was the computer, replaced it, nvr had the problem again.
  9. Heavyd
    Heavyd Road Train Member
    7,816
    6,271
    Feb 4, 2009
    Before we start replacing $3000 ECMs, lets look at the ignition and ECM feed wiring like the guys said. Anj8488, I bet in your case they ordered and replaced the ECM and road tested it, same problem, then repaired the wiring without telling you, making you think the ECM was faulty!
  10. kazungu80
    kazungu80 Bobtail Member
    17
    8
    Aug 27, 2012
    my FL century was doing same exact problem ,mainly when i went through bumpy roads.had a loose ECM wire at the batteries fixed it and solved the problem.good luck buddy
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    my truck would try to shut down only on hard right turns. bad wire connection at e.c.m. ground. replaced entire ground wire.
