International 4900 Dead DT466E
Discussion in 'International Forum' started by cj_kid5, Aug 11, 2018.
  1. cj_kid5
    cj_kid5 Bobtail Member
    I have a little day cab international 4900 with the dt466e out of Pepsi. I had the truck in running condition but it had bad batteries. I pulled them out and swapped brand new ones in a few days later. All the connections and jumpers are good and set to where they shoukd be. One small problem being that the truck will turn over but not fire, and while trying to find the reasoning (likely a blow fuse), I discovered that the positive wire from the alternator was blown out of the alternator with the stud in tow. Upon replacing, the exact same thing happened. Any ideas?
    Looks like my ECM is getting power from the 40A fuse in the battery box. Any common places to blow and casue this?
  3. cj_kid5
    Just an update: I moved the truck inside and am finally gettinga chance to look at it. Im used to the old mechanical trucks that I could get running without a battery within a matter of an hour. Is there a way to completely bypass truck systems to just get it up and running? This is a yard tractor so im not worried about lights, radio, etc
  4. AModelCat
    159,057
    If it ran before replacing batteries, verify your connections. You may have a ground to power or a power to ground.
    Hulld and Roger McG Thank this.
  5. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    When you crank, is the tach showing rpm?
  6. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Follow the alt wire all the way untill it hooks up, you may find a rubed place in the wire that is shorting out your truck?
  7. Jd richards
    Jd richards Bobtail Member
    Texas panhandle
    My 99 ih 4700/dt 466 e is draining all juice from batterys, with key off and out. What could this be ?
  8. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    You’d have to do a parasitic draw test to isolate an issue like that
