International 8300 with Detroit 11.1L - computer questions
Discussion in 'International Forum' started by alfio, Feb 20, 2023.
  1. alfio
    alfio Light Load Member
    65
    33
    Jun 2, 2021
    Hello all,
    Two questions:
    1) Anybody else have an International with the Detroit 60 (11.1L)? I would like to reset the computer so I can get actual / current codes. I'm not sure what the procedure is (I don't have a manual) but this is what I'm doing: I'm holding down the 'Diag' button and counting blinks on the 'Warn Eng' light.
    2) Would eventually like to get the onboard computer to connect it to an OBD2 reader. Is that possible? The truck has an older style OBD type connector: square type with 6 slots on top, 6 on bottom). It has the following wires: 1) purple wire, 2) white (ground), 3) black with stripe (ground), 4) black (voltage ranging 1.2-3.3V), and a battery source (13+V). I have an OBD2 type connector from the junkyard that would connect to the reader if I knew what wires to connect to what pins. What pins would I have to match to get the reader to communicate with the onboard computer (assuming it is possible)?
    Thank you
  3. Inderjit
    Inderjit Heavy Load Member
    742
    721
    Sep 17, 2017
    What year of truck? Can you post a picture of the diagnostic connector?
    The last eight of the VIN as well I might be able to find a diagram.
    alfio Thanks this.
  4. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,465
    Mar 18, 2021
    St Malo mb
    11 litres were great little engines that lasted forever. I don’t remember any mechanic using anything but a laptop to check codes . Maybe something like a bully dog or atc code reader would work on the early series 60. Many ecms of that era would lose battery life iirc
    alfio Thanks this.
  5. alfio
    65
    33
    Jun 2, 2021
    1993 - last 8 of the VIN are RH567992
    thanks!
  6. alfio
    65
    33
    Jun 2, 2021
    Anybody else familiar with the 11.1L? Thanks
