International 9200i Eaton Speed Sensor location?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nogascans, Jan 31, 2022.
  1. nogascans
    nogascans Bobtail Member
    Our 2001 International 9200i, 12.7 Detroit Diesel with Eaton transmission has an issue I'm trying to fix. 2nd owner and working thru a hodge-podge of miss-steps and band-aids.
    Error Code stored and comes back after clearing- FMI=12, SID0084, SID 84 error code). (Timing actuator #2).
    Symptoms include speedo that sometimes jumps, tach does similarly along with failure of cruise control to function.
    Assuming I can find the sensor in question, and a test chart, I am leaning towards faulty speed sensor, and I am trying to find the correct unit on the Eaton transmission to possibly test.
    Looking from the top (cab access panel) I can make out a total of (4) four sensors on tranny. Pair on the top look the same and mount into body and are a solid plastic with built-in retaining hole. Pair on the tail housing (one at near 12 o'clock and other at :15) have a different look to them with bolt/clip/sensor.
    Am I in the right neighborhood or missing something?
    Thanks in advance for any help.
    Cheers,
    David
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,489
    6,540
    Aug 26, 2014
    At the back. I thank one is for the ECM and the other is for the Gauge. If the tach is doing the same thing it is probably not the sensors.
    You can try swapping the connectors from one to the other as a test. However that does not sound like your problem.
    qak Thanks this.
  4. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Speed sensor is by the transmission yoke and can look like one of these.
  5. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    Tach reading comes from the ECM on a 2001 International.
  6. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    Try removing the center dash where the tach and speedometer are located and unplug the harness and plug it back in.
  7. Big Road Skateboard
    6,266
    34,548
    May 2, 2021
    The tach is ECM driven. The cruise and speedo sound like a loose transmission yoke nut
    spsauerland Thanks this.
  8. qak
    qak Bobtail Member
    23
    5
    Dec 22, 2009
    topeka ks
    First thing you do is verify CLEAN battery connections, especially the 10 gauge wires in the battery box, then follow the ecm ground and power wires and verify those are good. Next is the connection for the cam sensor, after that you can try swapping the 2 speed sensor connections at the rear of the transmission.
