International 9300 No RPM or Speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mrahe, Dec 30, 2019.
  1. mrahe
    mrahe Bobtail Member
    Dec 30, 2019
    Have a 1995 International 9300 with 60 series Detroit and Super 10 transmission. Everything was working fine on the truck until I took it in to a local welding shop to have the frame shortened on it. Now when key is turned on all gauges peg out and go back to 0 like they are supposed to. Truck starts perfect with no issues but tach stays on about 800-900 rpm and speedometer stays on 0. Read a lot on it possibly being an issue with the speed sensor on the rear of the transmission but would this effect the tach reading as well? Also does anyone have any specs on this sensor to ohm it out and test it before I replace it? Really lost on this one.
    Thanks in advance.
  3. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    Those are probably electronic gauges that get their data over a datalink to the engine. I would try another speedo/tach module for a test. The diagnostic connector you plug into check the engine for codes will also connect to the cluster module. So if you plug in and can communicate with the engine, the datalink wiring is ok.
    mrahe Thanks this.
  4. mrahe
    Dec 30, 2019
    Wanted to give an update on this. Finally took truck in and found that there was a short on the ABS module that was causing the datalink to go offline. Unplugged ABS module and everything functioned properly.
    Heavyd Thanks this.
  5. mrahe
    Dec 30, 2019
    spsauerland and Heavyd Thank this.
  6. JCFarms
    JCFarms Bobtail Member
    My 93 model 9300 international is doing almost the exact same thing as you described with your truck. Everything was fine never had a single issue with it. The speedometer just quit working completely and my tachometer doesn’t go up as high as normal now. They still both function and move when you turn the key on. I replaced the speed sensor thinking that was most likely my problem. That didn’t fix it. Wiring seems to be ok. Where is the abs module located on these trucks? Thanks
  7. JCFarms
    Abs module location on 9300 international?
  8. Ridgeline
    22,398
    116,407
    I thought they started to put ABS on 1997 and later years.
