International 9400I displaying instability when changing lanes.
Discussion in 'International Forum' started by bluerhino, Aug 28, 2021.
  1. bluerhino
    bluerhino Light Load Member
    107
    7
    Mar 10, 2013
    Hello everyone. I have 2006 did not drive the truck for last 3months few days ago put 8 new driver tires 2 new trailer air bags.on my first load I noticed that the truck is not stable when changing lanes its swerving my shocks are 5months old alignment is good need you help fellows. Thanks
  3. AModelCat
    161,684
    Check tire pressure.
    New rubber is always a bit squirrelly compared to worn tires.
  4. bluerhino
    107
    7
    Mar 10, 2013
    My tire pressure is good all the way to trailer
  5. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Was the load top heavy, and being out of the seat three months, plus recent work on the truck got you paranoid possibly? Also you said two new bags on the trailer. Are they for sure airing up all the way? Only two full bags will make it sway.
  6. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Believe it or not, like mentioned, new tires can have a loose feel. This is because of the new tall lugs of rubber that are bending and flexing to give you an unstable or wobbly feeling.
    ProfessionalNoticer Thanks this.
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    You'll probably lose some mpgs too. New tires are great, but there are negatives.
  8. bluerhino
    107
    7
    Mar 10, 2013
    Thanks heavyD yes the ride sometimes is unstable I hope it's the new tires
    Heavyd Thanks this.
  9. bluerhino
    107
    7
    Mar 10, 2013
    Thanks for your response. Load was light checking my air bags valve will let you know
    God prefers Diesels Thanks this.
  10. jamespmack
    216,333
    Yes all new lug drives will do this.
    I can tell you, new 19.5 Goodyear's on a single axle rollback will scare you to poop your shorts.
  11. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    You can just reach under there and push on the bags with your hands. I just know I've forgot to shut off my dump valve before, and only having one bag on each side trying to control body roll is pretty noticable.
    But like other's said, I'm going with new tires being the culprit. Takes a bit for the tread to get compacted.
    jamespmack Thanks this.
