International Eagle 9400i - Problems to build up pressure
Discussion in 'International Forum' started by Lumenusa, Sep 12, 2012.
  1. tktony
    tktony Bobtail Member
    I have a 99 9400 that will build air in secondary tank but not primary. Any suggestions would be helpful
  3. tktony
    I have a 99 9400 and my secondary air will build but not my primary any suggestions
  4. Truckers Report Jobs
  5. Heavyd
    Heavyd Road Train Member
    7,780
    6,218
    Feb 4, 2009
    Primary and secondary tanks are protected by an inlet check valve. Yours could be stuck closed on the primary tank. Also, your gauge could be faulty.
  6. tktony
    Check valve was stuck. Thanks. Next problem engine is all new runs very well until you back out of it about half way then get back in it. It will start missing until you back completely out of it count to three get back in the throttle then runs smooth until you back out a little then same thing over and over. N14 new filters,fuel and injectors but no engine codes or check engine lights. Totally stumped. Bad injector getting air in the lines ecm????
  7. Heavyd
    7,780
    6,218
    Feb 4, 2009
    Make up a new fuel line and connect it at the pump inlet and just run it straight into the fuel tank and try it again to see if it is sucking air somewhere.
  8. Kalo2017
    Kalo2017 Bobtail Member
    Hello, I have a 1999 International 9400 series. The shifter stayed in the high position and will not split to the low end. I hear air and the splitter has 3 lines, black, GREEN , and brown. I see the black and green, but not the brown fitting.
