International lonestar hard to keep in lane
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Lonestar1990, May 15, 2021.
  1. Lonestar1990
    Lonestar1990 Bobtail Member
    5
    Hello to all the brother drivers i really need help and advise here ., so i got this truck for like a year now ,,in the past couple of monts i notice that the truck was doing something funny and is a little hard to explain unless you're driving to feel it '' but basically the truck feels like swinging on the rear axels '' like you're driving and you steer to the right and you can feel the back of the truck goin the opposite way '' when is loaded is not as bad but it does the same ' I've done a lot to the truck trying to fix this but i haven't got to the problem yet'' any help and advice are welcome
  3. Heavyd
    Heavyd Road Train Member
    7,779
    6,217
    Feb 4, 2009
    Alignment? Check suspension? Dry 5th wheel?
    Lonestar1990 Thanks this.
  4. Lonestar1990
    5
    Alignment was done , 5th wheel never dry , and suspension has been checked at a couple of mecanic and also the international dealer. , but they all say not to see anything wrong but the problem is there so there might be an issued ,, i feel that it might be suspension couse when its heavy it handles a litte better.. Also been checking steering sistem but it really dont feel like a front ploblem
  5. Heavyd
    7,779
    6,217
    Feb 4, 2009
    Same trailer all the time?
  6. F4T6UY
    F4T6UY Medium Load Member
    567
    1,807
    Oct 24, 2017
    Very South Texas
    Do you hear a ‘knock’ underneath the sleeper if you rock the cab back and forth? Cab stabilizer bar?
    My bushings were shot, and it caused a similar, yet subtler, effect.
  7. Lazer
    Lazer Road Train Member
    1,795
    2,863
    Jan 22, 2017
    Were all axles aligned?
  8. Lonestar1990
    5
    It does the same with or without the trailer
  9. Lonestar1990
    5
    Yes sir i allways do alignment on all axels
  10. Lonestar1990
    5
    Will have to check that but i really dont think that the problem is the cab ,it feels went steering left or right that back axels are like trying to past the front axel ' like if they are not following the steering wheels or front axel line
