International S1754 DT360 Fuel Problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Loaderman22, Jun 27, 2019.
  1. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    If the truck was parked with the manual fuel shut off pulled the rack could be stuck closed.
    The side cover can be removed with the pump still on the truck. It is close quarters but the locks under the helixes can be tapped on with a brass punch an small hammer. This is watch type work and I never should have said hammer. Go back and forth with brake cleaner and penitrating oil.
    If that is your problem and you get it moving do this before starting. Find a friend with a short 2 X 6. Remove the turbo air inlet. Use that to shut it down it the rack sticks open.
    Heavyd, spsauerland and Navtech Thank this.
  3. BoxCarKidd
    4,525
    6,586
    Aug 26, 2014
    If that is your problem and you get it to move at all use the stop cable to pull it back. Work it back and forth until you are comfortable with it before start up. Let us know what you find.
  4. Loaderman22
    Loaderman22 Bobtail Member
    17
    9
    Jun 27, 2019
    Just wanted to pass along that the rack was stuck, but to be safe I sent it out for a rebuild & reinstalled it last weekend with great results! She purrs right along now, even drove it home. Thanks for all the help
    BoxCarKidd, Heavyd and jamespmack Thank this.
  5. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    You did the right thing. Glad to hear it runs great!
