Inverter Crisis!
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Jersey Trucker, Jul 20, 2008.
  1. Jersey Trucker
    Jersey Trucker Light Load Member
    60
    4
    May 4, 2008
    Lumberton, New Jersey
    Hey everyone, I just had a Cobra 1500w inverter installed in my truck and with the fridge plugged in and running everything is fine. Phone charger, laptop, etc everything is okay. But...when I try to fire up the microwave (800 watt) or my coffee pot (900 watt) the inverter beeps and then shuts down for a few seconds before starting up again. What the heck? 800 watts shuts this thing right down! I'm getting frustrated with this mess, my first time using an inverter and I ain't having no kinda luck! Installation looks good, very heavy guage cables feeding into it and this happens even with the truck running. HELP! The cold leftovers and truck stop coffee is killing me! LOL Any advice would be much appreciated. :biggrin_2554:
  3. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Try running your engine when you fire up the coffee maker or the microwave.
    How many things you have plugged at one time makes a difference too.
  4. Otter
    Otter Light Load Member
    298
    212
    Mar 16, 2008
    Milton, VT.
    1500 watts isn't much, you're exceeding the peak at start. How long are the cables? You should have 4 gage cable, preferably welding leads. The longer the cable, the more loss there is, and the larger the cable should be.
  5. Bigray
    Bigray Road Train Member
    1,135
    383
    Nov 23, 2007
    Tampa, Florida
    i have a 2550 inverter and it runs my microwave w/ no problem's
    i used no. 2 wire fyi.
  6. Pur48Ted
    Pur48Ted Road Train Member
    3,643
    5,981
    Jun 14, 2006
    Grand Rapids, MI
    A 800W microwave might need over 1500 watts when it initially fires up, same with the 900W coffee pot. But you didn't mention if the inverter was a 1500W "continuous" or 1500W "PEAK".
    A good rule of thumb is at least 2X the rating you need; if you run microwave (800W) and coffee pot (900W) at same time, you would need at least 3500W inverter. I run a 3000W continuous (4000W Peak) and I haven't had any problems in several years.
  7. Kaonix
    Kaonix Light Load Member
    51
    9
    Jul 23, 2008
    In my, Truck
    My coffeepot has an adjustable heating element, and if I crank it up it will overload my 3000watt inverter. I have since stopped using the inverter and bought a 3000watt generator mounted on my catwalk and the coffeepot gives it hell when on full blast but it handles it. I don't know if that's an option for you but you might look into it. In my opinion, 1500watts really isn't enough. Roadkill is right, the continuous wattage might be fine, but it's the startup wattage required that's killing you. I wouldn't run anything less than a 3000 watt inverter for microwave/coffeepot. Anything with a heating element takes alot of juice!
  8. Redneck_Inc
    Redneck_Inc Bobtail Member
    26
    7
    Jul 27, 2008
    Windsor Ontario
    i run a 1000 watt inverter and have no problems as long as i only run one thing at a time
    i use a seperate 600 watt for my tv and vcr/dvd player so i can leave them running while im cooking
  9. BobC
    BobC Medium Load Member
    409
    57
    Jul 8, 2007
    Cincinnati, slOhio
    That must be one hell of a coffeepot!
    I looked up the typical household appliance wattage draw to find the average coffeepot only draws about 200 watts per hour.
    A coffee maker drew upwards of 900 watts per hour.
    If you can "dog" a 3k inverter or generator with it, it's either on fire or you're heating the engine water for the truck next to you.
    There must be something else going on that isn't immediately apparent.
    Kidding aside, I can only suspect your adjustable temp coffeepot may have a "switching power supply" in it that has a poor power factor rating which means it could be confusing the inverter's load sensing circuitry.
    I suppose it's possible as well for a bad power factor device ( like inductive loads) to confuse a generator's load sensor as well?
    What brand/model of coffeepot is it? I'll look up the wattage specs for it.
  10. Kaonix
    51
    9
    Jul 23, 2008
    In my, Truck
    I know it's a Mr. Coffee. I'm not sure the model as I'd have to dig it out of the cabinet and unplug it and reset my clock. It has a big clock on the front with a stainless panel around it. Bought it last year.
  11. Salco
    Salco Bobtail Member
    32
    Jul 29, 2008
    Toronto Ontario
    Get a better inverter.
    I now have a 3500watt inverter, and it seems to have enough power for a 19" CRT tv, 900w microwave, 100w laptop, and many other small accessories.
