Inverter issue's
Discussion in 'Ask An Owner Operator' started by Trucker327, Jul 11, 2019.
  1. Trucker327
    Trucker327 Light Load Member
    176
    20
    Dec 24, 2017
    I have a 3000 watt inverter...i purchased a portable a/c unit...112 volts..when the tractors off and i plug in the ac...about 15-20 mins the inverter starts making this lpud beeping noise...I checked the wires..checked the ground..checked for smoke or smell (in case of fire)...but nothing...I cant figure out why theres a problem with the inverter..with such a strong power flow...and no i dont have anything else plugged in with the ac...has amyone had this problem before?
  3. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Not grounded properly, u need an 200 inline fuse might not be big enough,
    FlaSwampRat Thanks this.
  4. DUNE-T
    DUNE-T Road Train Member
    6,950
    16,861
    May 10, 2015
    Detroit, MI
    It's too much for that invertor and it starts crying. The AC unit takes too much power
  5. Trucker327
    176
    20
    Dec 24, 2017
    Hmm..is there another possibility? I have 2 grounds...speratly..both 0 gauges with fuse & a fuse holder on each of em...when i plug other things..like chargers or a cooker...i have no issue what so ever with it...also what do you mean.. 200 inline?
  6. Trucker327
    176
    20
    Dec 24, 2017
    So even tho its a 3,000watt inverter...it cant handle a 112v ac??
    86scotty Thanks this.
  7. 86mechanic
    86mechanic Medium Load Member
    372
    62,095
    Sep 6, 2016
    Northridge, CA
    Most inverters have a low battery voltage shut off.
    Have You tried it with the truck running?
    Expeditor Thanks this.
  8. Trucker327
    176
    20
    Dec 24, 2017
    Yes i have...and whem its running...theres no issues at all...i can have the ac with a powerful fan on at the same time...no problems..
  9. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    What brand is it? A good one with that rating would cost about $3,000.
    brian991219 and FlaSwampRat Thank this.
  10. Trucker327
    176
    20
    Dec 24, 2017
    Strongway
  11. DUNE-T
    6,950
    16,861
    May 10, 2015
    Detroit, MI
    It's not about Volts, it's about continuos Watts
