I just purchased an 03 780 and have no 120v power either from the inverter or when I"m plugged into ac current.
The fuse on the inverter is good as are the connections and the switch on the overhead console is feeding power to the inverter. Anything else I can look for?
Inverter/shore power problem
Discussion in 'Volvo Forum' started by exfarmer, Nov 4, 2011.
check for 12V power supply on inverter first
did you ever find the prob?
Not with the inverter but I did find fault in the truck circuit. It has a ground fault interrupter and it was faulty, a dead short. I haven't found anyone to test the inverter itself. It is a XANTREX sealed unit.
scatruck Thanks this.
