Inverters is this one any good?
Discussion in 'Questions From New Drivers' started by HD_Renegade, Sep 1, 2011.
  1. HD_Renegade
    HD_Renegade Road Train Member
    1,470
    607
    Dec 20, 2010
    North Carolina
    Cobra CPI-1575 1,500 Watt Power Inverter
    I dont really know much about them. Would like to be able to power a mini fridge and use a small micro-wave
    BrandCobra ModelCPI-1575 Spec TypePower Inverter Specifications1500 Watts Continuous Power
    3000 Watts Peak Power
    Remote On/Off Capable
  3. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    1500watts should do the job. Brand isn't a real big issue, but one of the best brand of inverters, as recognized by the TMC (Transportation Maintence Council), is the Xantrex brand of inverters.
    Key thing is to have any inverter wired up and grounded properly. Best advice is to have a tech in a shop wire it up for you, unless you have good experience doing this.
  4. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    Thank you for the tips, I will look up that brand. The truck shop has offered to hook it up and said they will supply the cables and fuse too, at no charge.
  5. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Well, the Xantrex inverters are not cheap, but like with most things, you get what you pay for. Do a search on the Xantrex Pro series 1800 watt inverter. That is a darn good one at a reasonable price. Many boating stores carry these online. I did a quick search and found one at $310. You could probably find a place that can beat that. Either way, that one is a solid inverter with low interference and will last you a long, long time. Definitely not one of the inverters the truck stops sell. But like I said, you get what you pay for.
  6. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    most of the time the cables they use are way to small.... the cables that came with my 1500w invertor i use on a 800w invertor. the cables i have on my 1500w invertor are so thick that i had to trim a little wire off the sides to get them to fit and it has twin 50a fusses.
    if you have a mirco and a fridge i would unplug the fridge when you run the mirco, over time it will be to much for a 1500w invertor, remember that 3000w is only for about 1 sec.
  7. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    Yes I was thinking that I would need to do that just for added protection, unplug the fridge before using the micro-wave.
    I know very little on electric and what is needed for what with this stuff, but from what I read 1500 would be a good size, so that is why I am asking the folks that have done this before, and use them all the time.
    Thank you
  8. Tazz
    Tazz Road Train Member
    2,821
    1,133
    Oct 25, 2009
    Lynchburg,Tn
    The Cobra I got lasted about 16 months+/-.
    Replaced it with a Power Driver 2000 watt bought from Amazon($139 free shipping) and have had it about 2 years+ /-.
    Make sure they put in an inline breaker!!!!
  9. flood
    4,161
    4,031
    Dec 25, 2010
    a 1500 wil run almost anything you will have in the truck, we have alot thats why i added a 800w
  10. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,441
    Jun 9, 2010
    Home
    I have a 2500 watt cobra, I bought back in 99', and to date, it's never giving me a problem
  11. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    I bought a 1500 powerdrive unit at the Pilot tonight for $139.00 out the door price. This should take care of what I need.
