Inverters.
Discussion in 'Questions From New Drivers' started by CP1995, Nov 22, 2017.
  1. CP1995
    CP1995 Bobtail Member
    34
    17
    Sep 21, 2017
    new OTR driver, bought a 500 Watt inverter, how quickly would that drain my battery, I am with a company that doesn't allow you to idle your truck so just wondering before I get stuck out there.
  3. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Well if they won't let you idle, I'm assuming they've equipped their trucks with an APU, if not you might want to take your inverter and get on down the road to a place that cares a bit about their drivers.
    rabbiporkchop, Tb0n3 and Wingnut1 Thank this.
  4. CP1995
    34
    17
    Sep 21, 2017
    That good ole Schneider national cheapness. No APU.
    rabbiporkchop Thanks this.
  5. tscottme
    tscottme Road Train Member
    It's current, measured in amps, that drain your batteries. If you have a 20 watt cellphone charger hookedup to 500 watt invertet you are only using a little over 20 watts. If your inverter is powering a 500 watt device with engine off it will drain faster. Every power device will list voltage and either amps or watts. A watt is voltage multiplied by amps. I don't know capacity of your batteries or current consumed by your device (s).
    Dan.S, SingingWolf and pattyj Thank this.
  6. tscottme
    I can run my electric cooler, which consumes about 10 watts for 24 hours in moderate temperatures without being unable to start truck. I would be worried if consuming that much power for another 5-12 hours. But my truck & batteries are not your truck & batteries. Experiment when you are near a jumpstart opportunity. Carry jumper cables.
  7. Chinatown
    Chinatown Road Train Member
    74,676
    169,801
    Aug 28, 2011
    Henderson, NV & Orient
    You're pulling tankers aren't you? Not too many tanker companies have APU's.
    I think Oakley Transport has APU's.
  8. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I wouldn't plug in more then one item at a time.I always had good luck with inverters sold at Walmart.But then again I only used it for my cell phone.laptop and portable DVD player.
  9. CP1995
    34
    17
    Sep 21, 2017
    Yeah I just wanna run a TV and a fire stick
  10. secorp
    secorp Medium Load Member
    320
    123
    Jan 16, 2013
    Lakeland Florida
    Most have an alarm that lets you know when you get down to 11.8 volts to 12.4 volts. some have auto shut down.
  11. LilBudyWizer
    LilBudyWizer Light Load Member
    185
    169
    The voltage is an indication of the charge on the batteries. A fully charged battery is typically 13v. Below about 12.3v your ability to start the truck gets questionable. It should be pretty linear so just turn the ignition on every hour or so to see how fast it's dropping.
