Invertor problem
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by bmw535, Mar 17, 2008.
  1. bmw535
    bmw535 Bobtail Member
    7
    Phila, Pa
    I have a 400 watt invertor when i have my icon idle system on and the truck starts it shuts down and restarts back up i am worried about it blowing out the invertor or whatever i hooked up to it at the time, is there a way not to have this happen?
  3. gearjammer-2000
    gearjammer-2000 <strong>Clutch User</strong>
    670
    205
    Dec 18, 2007
    columbus Ohio
    try wiring into another circuit than the one you are using or wire it directly to the battery with a fuse in line of course
  4. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,055
    Jul 15, 2007
    TEXAS
    Mine did the same thing. It has not blown my 400w inverter. I used it for my tv and dvd player. If your using it for your notebook, it will be hard on it.
  5. Pur48Ted
    Pur48Ted Road Train Member
    3,643
    5,981
    Jun 14, 2006
    Grand Rapids, MI
    The inverter shuts down because the "supply" voltage is interrupted when you start the truck. All of the "accessories" shut down during the start cycle.
  6. jardel
    jardel Light Load Member
    110
    21
    Mar 8, 2009
    BUFORD,GA
    my stays on all the time i turn the swich off it still stai on.
  7. kajidono
    kajidono Road Train Member
    6,422
    4,659
    Jun 1, 2009
    Streetrat
    It kills my 300 but doesn't bother my 800 at all.
  8. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    My 800 will sometimes shut off, sometimes it wont.
    Question though, running my laptop, with my tv plugged in but not ON how long should it take for my batteries go die on the truck? I swear if i have the truck off and just my overhead light on with laptop on for an hour, i start getting a beep that i am about out of juice and I have gotton really good at hooking my reefer up to my truck batteries via jumper cables.
  9. cherokeechief
    cherokeechief Light Load Member
    142
    30
    Aug 10, 2009
    Gilson, il
    some of the less expensive invertors, will do that. the ones that plug into the sig lighter or acc. outlet. it is a common thing, but the only thing that will happen is cause frustration when you have to restart a movie that you was in the middle of, now if you went with one that was of a higher wattage and was direct connected to the batteries usually won't have that problem.
  10. lonewolf4ad
    7,743
    7,773
    Nov 4, 2008
    Mine IS connected directly to the battery.
  11. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Do you spend a lot of time gaming? Or running high resource programs?
    My old laptop would suck the life out of my batteries, just like yours. But it generally occured when I was running Ice WinDale or another heavy resource game that forced my fans to stay on high all the time.
