Irregular Tire Wear on Steers
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Proxy, Jul 26, 2019.
  1. Proxy
    Proxy Light Load Member
    165
    54
    Sep 3, 2018
    I just noticed this when doing a walk around on one of our trucks, the driver doesn't experience any issue while driving, the wear pattern is primarily on the right front steer and mostly on the inner shoulder of tire, it is a 2015 T680 if that helps, any ideas? the top pictures shows what appears to be more of a flat spot than an elongated pattern you see on rest of tire
  3. boneebone
    boneebone Road Train Member
    2,234
    2,268
    Mar 13, 2009
    It could be a bad drag link, front wheel bearing has play, bad kingpins, bad tie rod ends, bad front shocks, incorrect tire pressure.
    Proxy Thanks this.
  4. skellr
    skellr Road Train Member
    8,737
    12,179
    Jul 17, 2011
    The Village, Portmeirion
    What does the other front tire look like? If it's worn like that on the outside edge of the drivers side tire I'd say the driver is a zipper hugger. Running on the outside edge of ruts in the road.
  5. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    Look up Mike Becket of MD alignment. He can tell you exactly what is going on.
    Proxy and Intothesunset Thank this.
  6. Intothesunset
    Intothesunset Road Train Member
    2,290
    4,874
    Apr 15, 2019
    truck
    Try rotating them. It can't hurt.
    And put new shocks on truck if they are more than a year old. Yearly axle alignments are recommend.
    Proxy Thanks this.
  7. PE_T
    PE_T Road Train Member
    I had a similar issue a couple years ago, and the problem was the leaf spring bushings.
  8. Rideandrepair
    16,526
    53,944
    Aug 8, 2015
    That’s called river wear. Common problem, sometimes even if everything’s good, simply time for new tires. My old Truck always had it after 80-90k. Still did it after bushings, alignment, shocks. Just weak point of steer tire. Mine was both tires though, Get everything checked, they’ll figure it out, hopefully just needs alignment. Meanwhile flip tire around, or rotate both
    Hulld and PE_T Thank this.
  9. FreightyAK
    FreightyAK Light Load Member
    51
    42
    Aug 7, 2018
    AK
    Maybe alignment. I had similar wear and thats what it was. Measure from the inside of the wheel to the frame on the front and back of the wheel.
    PE_T Thanks this.
  10. alaskanmaster212
    alaskanmaster212 Bobtail Member
    4
    talk with mike at vantage in anchorage and set up a appointment to have it looked at . theres is a lot of factors it could be
  11. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Could be a belt that shifted.
    PE_T Thanks this.
