just got my truck washed yesterday and today the voltage is showing a lil higher than the normal 14.0 im use to getting. Is this a cause for concern?
Truck is a 2012 cascadia dd15
Is 14.6 volts too high
Discussion in 'Ask An Owner Operator' started by dztruck, Jun 11, 2018.
Page 1 of 3
13.8 is the norm. Could be a bad battery that won't charge.
Past 3 trucks I've been in all 3 generated 14.1v. As long as your system is between 13v and 15v you're system is within normal limits
Hurst Thanks this. -
Ok its just a lil odd that ive had new batteries in it for 6 months n it always showed around 14.0 volts.
After i got it washed (which they broke my antenna) the next day its showing 14.6. -
14.6 is a little high but not too high to be concerned. If it continues to climb, it will overcharge the batteries and boil them out, basically ruining them. It’s accompanied by a sulfur smell. The voltage regulator may be going out, just keep an eye on it.
bzinger Thanks this. -
Tap on the alternator. May have dust built up on brushes.
I'm at 14.2 on my Cascadia . I had new batteries out in and they ran at 14.3 to 14.5 for a day .
I think you may be overcharging the batteries. I went through 3 sets of batteries on a new Pete because the factory shipped our trucks with a defect. It charged 14.6 constantly. Eventually, our Dealer fixed it free of charge.
I had this on my 2016. On the PNDB module on the firewall there is a fuse “Alt Remote Sense” , it is probably blown. Only a five amp fuse.
Mine was blown , alternator was at 14.6, went back down to 14.0 after that.speedyk Thanks this. -
It’s raining right now and my 2015 cascadia shows 14.6. May catch fire and burn to ground if I’m lucky
shogun Thanks this.
Page 1 of 3
