Is 30,000lbs in the trailer a heavy load?
Discussion in 'Questions From New Drivers' started by Blackducati750, Aug 18, 2010.
  1. Blackducati750
    Blackducati750 Light Load Member
    193
    10
    Mar 11, 2009
    Bushkill,PA
    I'm a company driver out of PA currently driving a 2007 Freightliner Columbia Tandem Daycab with the 515hp Series 60 Detroit Diesel and a 10-spd trans. Not sure of the axle ratio.
    I pull a 48ft reefer trailer, delivering palletized frozen foods throughout PA, NJ, NY, and CT for a local supermarket chain.
    I'm not sure of the "tare" weight of the truck and the empty trailer, but a 22-24 pallet load usually weighs around 28,000 to 32,000 pounds as per the load paperwork.
    In NJ, on Rt.80 eastbound, exit 19, is the Allamuchy hill. A long steep uphill climb that will have you turning on your hazzard flashers 9 out of 10 times trying to climb it.
    I usually climb the hill in 9th gear and keep a steady 50-55 MPH the whole way up. I've only been a "real" truck driver for 2 years. I'm no diesel mechanic, but I see the HP ratings for a lot of trucks in the used truck market and 515hp is no slouch. Most trucks I see for sale online are in the 450-477hp range.
    Yet, most other trucks fly passed me up this hill like I'm standing still.
    I think to myself, "Yeah, I could go that fast with an empty trailer too."
    Then they pass me and I see the tag/seal on the back door. Jeez! That guy has a load in the trailer!!!
    So, are these other trucks packing 600+hp heat under the hoods. Or, is a 30,000 load considered heavy??
  3. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    30K is light.
    They could have 600hp or they could have 3000 pounds of pillows
  4. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    You still make it over the hill dont ya?
  5. Blackducati750
    193
    10
    Mar 11, 2009
    Bushkill,PA
    Yea. But in a "time is money" factor. I'd like to be able to climb hills at 70mph, not 55mph.
    Just wondering how much power to look for in my first used truck...
  6. Manny129
    Manny129 Light Load Member
    150
    25
    Aug 16, 2010
    Today I pulled 10 Boxes of Baseball cards and 1972 Corvette with my F-250 through the pass at 35 MPH. Trucks of all sorts were flying by me at 70 or 80. Man, hope my new 53ft and my 04 with 400HP engine can go through those hills at about 45 MPH, I only think I will only hit 35 MPH. I will be in NJ soon. Vegas isn't that great anymore.
  7. TheHealthyDriver
    TheHealthyDriver Heavy Load Member
    837
    274
    Jul 11, 2010
    Stony Mountain, MB
    The rear ends could be your downfall in this equation. But, unless you're doing nothing but mountain climbing, it's better to have the rears you do, I would imagine.
  8. RenegadeTrucker
    RenegadeTrucker Road Train Member
    2,754
    2,383
    Dec 25, 2009
    Montana
    You think you are going slow now, wait until you have 85,000 lbs on a trailer that weighs 20,000 with a tractor that weighs in at another 20, then you will be heavy.
    I have pulled that with a 435 3406E and a 15 speed.
    Some of it is gear ratio, the truck I was driving had a 3.90 rear end and 24.5's on it, there were occasions loaded heavy with it id actually be passing company drivers in thier freight shakers.
    If you have a 3.36 rear end, you can get it done on the flat lands, but on the hills you will bog down pretty good.
    My preference is a 3.55 rear end with 22.5 LP's on the drives.
    I know many company trucks are speced with the 3.36 rears because technically they get better fuel mileage.
    The other part of that is, the series 60 detroit isnt exactly what id call a torque monster.
    When I was a the first company drove for then leased to they had a 98 Kenworth W900L with a 515 hp series 60, 18 speed, 3.55's and 22.5's on it, it had a really hard time keeping up.
    When I bought my truck it was a 2000 Kw W900L with a 475 hp 3406E and a 18 speed, 3.55 rears and 22.5's, it would routinely leave the detroit behind when pulling a hill, and we were pulling some of the big hills out west running togeather.
    Once I had my truck turned up to a 550 I couldnt even run with the driver that was driving the detroit because he couldnt stay up with me and id always be waiting for him to catch up even when he was signifigantly lighter, im talking lighter like he had a load of insulation on and I had engineered beams.
  9. oldmacksrule
    oldmacksrule Light Load Member
    176
    160
    Aug 7, 2010
    If you don't like slow hills, don't get into flatbedding. LOL (When loading skateboards---which is usually heavy freight---the limiting factor is weight. 90% of the time you're running at max GVW. Van freight is usually lighter, though, so the volume of the box controls things.)
    In short, most flatbedders find themselves dropping into low range on state highways here and there in parts of of KY, TN, VA, WV, & etc, even with a decent engine.
    As for shopping for your own truck, wanting too much engine is a common mistake. The time saved up hills doesn't begin to make up for the fuel lost the rest of the time. Most experienced O/O's I know say a medium-sized motor and a 13 speed is the best compromise.
  10. Manny129
    150
    25
    Aug 16, 2010
    By Medium you mean 400HP to 470HP?
  11. TheHealthyDriver
    837
    274
    Jul 11, 2010
    Stony Mountain, MB
    470 is medium, I would think. I have a 435 Cummins boosted to 475, and I use it to pull Super-Bs through the mountains in BC. Gets me through every time.
