Is doing overhauls the same as a new? In that case, is it not cheaper?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Migueljs16, Jan 24, 2013.
  1. Migueljs16
    Migueljs16 Bobtail Member
    32
    6
    Nov 10, 2012
    Allentown PA
    My friend wants to buy a 2003 (pre emission) freightliner with a N14 plus, 10 speed, Wetliner, Triaxle, it has 37k original miles, and was barely because the company went under shortly after.
    The dealer is selling it for 65k, which with those miles, you're practically getting a new truck (hypothetically at least) then I found out that an overhaul cost around 15k, another 9k for the transmission, 5k for turbo and 7k more for the rears... comes out to 36k, buying a truck with high miles for 25k, and having those overhauls done, it STILL comes out cheaper...
    So I was wondering, when an overhaul is done, are you pretty much getting a clean slate on the engine and other units that were rebuilt?
  3. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    yes when you do a inframe you put new sleeves pistons rods mains crack is turned or replaced cam is speced and replaced if need. head is tested and rebuilt new vavles vavle springs injectors tested and replaced if needed. front gears are checked and replaced. pretty much every internal part is checked and replaced. on the tranny all gears syco and all are replaced same with the rears all new gears pinion the works. so yea its dang near new
  4. Gambi80
    Gambi80 Medium Load Member
    The transmission and turbo prices are WAY high.
  5. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    No, you do not get a clean state with the engine after an overhaul. There are many parts that do not get touched with an overhaul. Even the word, "Overhaul" is a variable term. You can overhaul an engine 50 different ways. A basic overhaul is just installing new liners and pistons, but put the old head and turbo back on. An expensive overhaul is a reman head, reman injectors, pistons, liners, full bearings, turbo, water pump and so on. Some of parts that never get touched during an overhaul, especially with a N14, is cam shaft and cam bearings, front and rear main seals, engine sensors, wiring harness, oil coolers, oil pumps, Jake Brake housings and so on. If you want a true clean slate with a full top to bottom engine warranty, replacement is the only way to go. That is the only way to be sure everything has been renewed.
    Oram Thanks this.
  6. Ruthless
    Ruthless Road Train Member
    9,100
    90,256
    Aug 28, 2010
    The City.
    Also that's considering that the truck you are rebuilding has all good wiring throughout no rust or other insidious problems present and has plenty of life left before those problems rear their heads :/ if the rest of the truck is good its worthwhile. Junk won't get better with a rebuilt motor.
    Heavyd Thanks this.
  7. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    How much will that cost?
  8. Heavyd
    7,812
    6,265
    Feb 4, 2009
    That is hard to answer without looking at the truck and having another conversation with the customer. While the engine is out, this is an excellent time for new motor mounts, clutch, exhaust and so on. Prices can vary to by location. It always pays to call around. I have a rule here, I don't give time quotes.
    rickybobby Thanks this.
  9. Hdhaulers
    Hdhaulers Bobtail Member
    4
    A big thing to consider also is with higher miles on the whole truck, you have to account for things like suspension wear, like U-Joints and rears, and even interior features like the seats, and switches. When it comes down to it, lower miles typically beat a rebuild in my opinion
  10. SemperFiServices
    SemperFiServices Medium Load Member
    379
    233
    Jan 29, 2013
    Indianapolis, IN
    I just bought a 96 IH 9600 for $3500 with 957k on the clock. I dumped another $3500 into repairs, and ran her 1300 miles this past weekend. It ran good, the tranny sucks, and it rattles and you feel every crack in the road, BUT I sitll only have $7000 into a good running truck. But if I could afford it, I'd love a newer conventional.
