Is Double-Clutching "Bad"?
Discussion in 'Questions From New Drivers' started by STransport, May 3, 2015.
  1. STransport
    STransport Light Load Member
    95
    19
    Oct 13, 2014
    Hudson Valley, NY
    Started work a company and it seems a lot of drivers frown on Double-Clutching and want me to focus on shifting without the clutch at all.
    Should I listen to them or drive how I want? I was going to try and focus on shifting without the clutch up-shifting and double-clutch down-shifting.
  3. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,300
    Nov 8, 2009
    The Highway To Hell.
    It's not bad, but you don't need to do it. Floating the gears is easier on you, and the clutch! Give it time, and you'll float the gears like a pro.
  4. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Drive how you want double clutching is the correct way to do it !!!! Does it hurt anything to float the gears? Not if done correctly !! however in missouri not sure about other states if you can't double clutch you won't pass the driving test unless you are in an automatic and then they put a restriction on your license where you cant drive a manual truck legally. When it comes to double clutch or float there is no right or wrong as long as you can safely shift the truck without grinding the hell out of the gears
    bobtrucks2204, SLANT6 and MZdanowicz Thank this.
  5. SLANT6
    SLANT6 Road Train Member
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    As said prior. Double clutching is the text book way to drive. I've seen transmissions destroyed by so called "floaters" that do not know how to properly change gears without the clutch. Properly done either way is acceptable, however double clutch is how it should be done on a road test.
  6. FozzyNOK
    FozzyNOK Road Train Member
    2,468
    3,802
    Jul 18, 2007
    Oklahomistan
    People float gears because they are too lazy to double clutch.. end of story
    MZdanowicz and rank Thank this.
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I thought it was people double clutch because they are too stupid to float.
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I never use the clutch. Ever.
    skellr Thanks this.
  9. rank
    rank Road Train Member
    9,918
    113,505
    Feb 11, 2010
    There are times you can float and there are times it's safer to DC. Depends on how much torque is on the trans at the time. Or the speed differential you have.
    If I'm loaded heavy climbing a steep hill and I need to gear down, I might DC in that scenario.
    If I'm coming off the highway loaded to a stop sign at the end of the off ramp, I might DC in that scenario.
    But just tooling down the highway listening to Ozzy's Boneyard? Float all day. Not sure why you need smarts for that.
    razor1983 and not4hire Thank this.
  10. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    I personally use about a 50/50 blend, so I guess I'm wrong x2 and right x2 which is what she said as she was leaving. But seriously, away from any driving test and once experienced and in the real world, I feel there is a time for both, and there are times to avoid floating.
    But if done correctly by someone who has a good feel for the truck, load, and drive-train system I don't see that it hurts anything to float. Once in a blue moon you may not hit it perfectly but it's not the end of the world.
  11. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    What about when taking off from a dead stop?:biggrin_25519:
