is downshifting required?
Discussion in 'Questions From New Drivers' started by wheretogo, Aug 18, 2012.
  1. wheretogo
    wheretogo Bobtail Member
    33
    passaic, nj
    Sometimes I feel more comfortable just braking a little and clutch+brake to stop. Do I have to downshift to pass the road test at the dmv?
  3. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    Yes you have to downshift, upshift, and generally know how to operate the vehicle. That's the POINT of the TEST
    TRKRSHONEY and WitchingHour Thank this.
  4. wood600rr
    wood600rr Bobtail Member
    36
    21
    Aug 10, 2012
    Palm Coast, FL
    No coasting is allowed, you must always be in a proper forward gear until you come to a stop
    Lepton1 and SingingWolf Thank this.
  5. Raiderfanatic
    Raiderfanatic Heavy Load Member
    814
    561
    Jul 18, 2010
    Hutchinson, KS
    If you can't downshift, you can't or don't have total control over your truck. At least in my opinion. It's been so long since I took the driving test, I don't know the answer. Personally, it never has crossed my mind to not downshift to control speed slowing down and stopping.
  6. Raiderfanatic
    814
    561
    Jul 18, 2010
    Hutchinson, KS
    If I remember correctly, you can't coast more than the length or your truck and trailer.
    SingingWolf and Toad87 Thank this.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,673
    18,442
    Nov 1, 2010
    Burnsville, MN
    It crosses my mind sometimes, like when I don't have time to downshift if I intend to stop in time.
    But, yes, the DMV test requires at least one downshift when coming to a stop. (In CA. I don't know other state's requirements.)
  8. wheretogo
    33
    passaic, nj
    I know how. But I'm a new driver and sometimes it feels easier just to brake slightly to slow down, then clutch+brake to stop, rather than decrease rpms to 10....clutch neutral...increase to 15...clutch gear...rinse and repeat... it feels too slow for me. But I will do more practice on it for sure
    so just using the brake to slow down and clutch+brake = coasting? didn't know that
    can I skip gears when downshifting tho? it takes too long lol
  9. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    Yes you can skip gears. When I took my road test I downshifted 10-8-6 and let the truck pull itself to the stop sign or light in 6th. That's how my teacher who is also an examiner told us to do it. The criteria on the test is that you be in a proper gear. Basically if you have to go because the light turns green you should just be able to hit the gas and not have a lot of hesitation and lurching. Since you will be pulling an empty trailer on your road test, 6th gear is fine. Just remember to put it in your starting gear after you stop.
    I will say that just because that works in GA, it may not work in your state. Ask your teacher and do it the way he or she tells you.
  10. stevep1977
    stevep1977 Road Train Member
    3,701
    22,370
    Dec 23, 2010
    Chicago, IL
    If you're driving in New Jersey, you better know how to downshift
    x1Heavy Thanks this.
  11. stevep1977
    3,701
    22,370
    Dec 23, 2010
    Chicago, IL
    Any time the clutch is depressed or the truck is out of gear (the same thing basically), it's coasting. Generally speaking you can't coast more than two truck lengths, or about 140 feet.
