Is it better to file a bridge laws or wait laws
Discussion in 'Questions From New Drivers' started by zoekatya, Jul 17, 2015.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    Is it better to file a bridge laws or axl weight laws
  3. zoekatya
    397
    99
    Mar 15, 2013
  4. truckon
    truckon Swamp Thing
    4,774
    15,917
    Dec 16, 2011
    Like I'd tell you!
    Where are you. Where are you going. What are you pulling.
  5. zoekatya
    397
    99
    Mar 15, 2013
    Virginia and Maryland at my axles all the way back
  6. zoekatya
    397
    99
    Mar 15, 2013
  7. zoekatya
    397
    99
    Mar 15, 2013
    Should I just go around the scales
  8. zoekatya
    397
    99
    Mar 15, 2013
  9. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    You're better off violating weight laws.
    Bridge collapses while you're on it you're not only at fault for being overweight, but you've destroyed public property, your trailer/tractor, you/your company thousands of dollars to fix it, your job and potentially someone's life could be impaired or lost.
    At least if/when you get caught at the scales, you get stopped, ticketed and then you have to wait for it to be transferred out.
    That being said... My advise is to call your dispatcher, be forceful and state that you ARE turning around and returning to the shipper because you're overweight. Don't go any further.
    In the future, if you're overweight immediately go back to the shipper if there isn't a scale on site. If there is one and you didn't use it, then that's on you.
    If there isn't one, then you'll also need to know your tractor's weight limit.
    My tractor 17,652lbs, average empty trailer, is roughly 15,000lbs. Means I can carry about 47,000 lbs before I'm in trouble.
    What's your total weight?
    Chewy352 Thanks this.
  10. zoekatya
    397
    99
    Mar 15, 2013
  11. zoekatya
    397
    99
    Mar 15, 2013
    Just made it past the Virginia scale house let's see about Maryland. Thank you for the thorough reply
