Is it illegal when a trucker change tire on the road by him self?
Discussion in 'Questions From New Drivers' started by c.w, Jun 10, 2023.
  1. c.w
    c.w Light Load Member
    108
    48
    Jun 26, 2021
    For example :
    a trucker has a spare trailer tire with rim
    he wanna to change a flat tire
    he has college certificate for heavy duty apprentice, he was trained and well know the standard.
    he has all the tools icld torque wrench, bottle jack etr....
    Does Diesel dogs will stop him to do it? or ticket? for what?
    Thanks for comment.
    austinmike Thanks this.
  3. Espressolane
    18,201
    113,080
    There is no law, regulations or code that says a driver can not do any service or repairs.
    If you have the tools and appropriate parts, there is no reason you can’t do the repairs.
  4. REO6205
    REO6205 Road Train Member
    13,168
    60,491
    Feb 15, 2014
    California.
    Change the tire. You're legal. Try to get as far off the road as you can.
    Opendeckin, cke, c.w and 3 others Thank this.
  5. Cat sdp
    Cat sdp . .
    21,183
    75,086
    Apr 8, 2012
    Orion's Belt
    Apparently in communist Canada it is illegal. Tire shop has to torque the lug nuts………
  6. AModelCat
    161,302
    Sounds like an Ontario thing. Never heard anything like that out here.
    Albertaflatbed, cke, Bean Jr. and 3 others Thank this.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,817
    18,692
    Nov 1, 2010
    Burnsville, MN
    So where do you stow all that tire changing equipment on the truck?
    And why would you keep all that stuff on the truck in the first place?
  8. drh72
    drh72 Light Load Member
    175
    301
    Aug 19, 2012
    Northeast Minnesota
    When I started driving for Monson Trucking in the 90's we ran Daytons...when we were issued a truck(International Cabover) it came with a 20 ton bottle jack, lug wrench, and spare tire mounted on a Dayton rim (supply your own cheater bar). Could change a flat and be on your way in no time in those days as Daytons don't need to be torqued nearly as much as pilot hubs or budds.
    Mattflat362, bzinger, cke and 5 others Thank this.
  9. Arctic_fox
    4,351
    23,451
    Sep 16, 2016
    Im not him. But ive done my own tire swaps. Doesnt take as much as you would think either. Ive carried a full spare + rim in my spare rack before. Just use a jack or 2x4 with your trucks air system. Carry a torque wrench and a mini air impact set up to hook to your service line.
    Takes up about the same room as 5 gallon bucket and as long as your side box aint a pigstye theres more then enough room. To swap tires off the rim just add a can of ether, a good sparker or box of matches (never needed them but i do have them) and a pair of breaker bars. Breaker bars also double as prypars and tarp adjustment stick so no extra room taken up.
    Bonus points for space if you have a tool box someplace. As for why? Ever lost a tire or worse two in the middle of no where with the nearest service truck being a good 3 to 12 hours away if you even HAVE signal? I have!
  10. Last Call
    Last Call Road Train Member
    7,568
    45,909
    Mar 15, 2021
    When did the DOT start carry'n torque wrenchs ?
    And do they put you OOS if the lug nuts are over torqued ? And make you back them off untill they are at the recommended torque specifications ?
    Most the Diesel Cops I've had dealings with aren't smart enough to read a torque wrench let alone know the correct procedure to check the torque
    what's next .. head bolt torque ?
  11. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,895
    Nov 26, 2020
    Easy, air jack 20 ton, air impact, spare on the catwalk. Start to finish used to swap container tires out in 30 min or less. Was a O/O so doing it myself saved a lot of money. Would bring the trailer back to my yard and swap out my good spare and put the busted one back on before taking it back to BNSF then put in a maintenance request at check in.
    cke, Oxbow and D.Tibbitt Thank this.
