Is it legal to drive it home like this?
Discussion in 'Ask An Owner Operator' started by Doing the best we can, Oct 9, 2022.
  1. Doing the best we can
    Doing the best we can Bobtail Member
    Oct 9, 2022
    So I have an axle that burned up some bearings and I took the hub off and tires ect,chained it up, no load on the trailer, the trailer is a trip axle. Is it legal to drive it home like that?
    austinmike Thanks this.
  3. Hammer166
    7,459
    27,034
    Aug 18, 2007
    ~8600+' and loving it!
    Absolutely. As long as you meet the weight limits on the remaining axles and the bad axle is properly secured, you're good to go!
  4. AModelCat
    159,388
    You took the tires off both sides I assume?
  5. Doing the best we can
    Oct 9, 2022
    No sir
  6. Doing the best we can
    Oct 9, 2022
    Thank you guys for the information. Be safe out there.
  7. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Put the tires on the top or in the trailer and inflate the air bags on the axle that has the tires still on them, so the other axle can't drag the road?
    singlescrewshaker Thanks this.
  8. singlescrewshaker
    4,837
    42,244
    Dec 31, 2017
    Little Havana, FL
    Take all 4 tires off the bum axle
  9. xsetra
    xsetra Road Train Member
    5,117
    6,987
    Aug 21, 2011
    Yes.
  10. Magoo1968
    Magoo1968 Road Train Member
    2,032
    5,426
    Mar 18, 2021
    St Malo mb
    You need to block off air to brakes and bags on lifted axle . PS make sure air leveling valve is on a lowered axle.. I pulled one home that way but mechanic placed leveling valve in a fixed position which meant over time air bags would drop . I had to stop every few hours to move valve to refill air bags..
