Is it OK to use starter fluid on a diesel truck engine?
Discussion in 'Experienced Truckers' Advice' started by Pmracing, Dec 31, 2013.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    My truck has been rough starting in these single digit temps. I probably need the batteries replaced.
    But a friend told me gave his a quick shot to help his start. Is that bad for any reason?
    Mikeeee
  3. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    I don't know, but it seems to me that since there is no spark, it wouldn't do much good. I could be wrong though.
  4. DrFlush
    DrFlush Road Train Member
    1,297
    2,707
    Mar 22, 2011
    Upstate NY
    I've done it and seen it done, but don't know if it is recommended
  5. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    OP must be a troll. Nevertheless, starting fluid should only be used on a diesel without glow plugs. Not on a spark plug engine, except your lawn mower.
    not4hire and Joetro Thank this.
  6. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    I have used it. It worked.
  7. Lonesome
    Lonesome Mr. Sarcasm
    11,468
    23,703
    Dec 15, 2007
    Northern Indiana
    NO, if you have glow plugs, or an intake heater.
    spindrift and not4hire Thank this.
  8. kalh7
    kalh7 Light Load Member
    186
    62
    Mar 28, 2007
    southern illinois
    Just because there is no spark doesn't mean starting fluid won't work. You can use it, just wouldn't use alot of it. If it's in the single digits I would plug the engine heater in if at all possible, would help alot.
  9. heyns57
    2,209
    1,011
    Dec 30, 2006
    Safer to use a charcoal grill under the engine with tarps wrapped around the cab.
    rocknroll81 and Shaggy Thank this.
  10. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Yep, you are wrong.
  11. TripleSix
    132,268
    starter fluid would probably work on engine compression alone. Starter fluid is more flammable than gasoline. A high compression gasoline motor would have a CR (compression ratio) of 13:1, and a diesel would have one over 20:1 put gasoline in a Diesel engine and odds are you would have uncontrollable predetonate on, which would probably put a rod through either the oilpan or the side of the engine block.
    I would use use starter fluid only in emergency situations.
    Extreme cold is hard on the batteries, and it's hell on your engine oil. I hope you are plugging in your block heater.
