Is it possible to have a pressurized air leak from a coolant line?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Froxtayle, Oct 23, 2019.
  1. Froxtayle
    Froxtayle Bobtail Member
    Posting a question for my dad here about his casscadia, there is an air leak coming from the port side of the engine in the back where it’s hard to visually confirm air leak sources. Bubbles appear to be coming from the coolant line and we are Hitting a brick wall trying to figure out where this air leak could be coming from. Any clues or suggestions?
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,080
    Sep 24, 2019
    Raleigh, NC
    With it being back of the motor area.. kinda makes me think of coolant lines going to cab/bunk heater.
    Still, shouldn't have air bubbles coming from a coolant line.
    Are you sure its coolant and not DEF?
  4. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    DEF lmao that goes to exhaust, not engine.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    coolant leaks coolant.
    Air leaks air. If you got bubbles after spraying Mr Soapy water on a questionable line it's air.
    If you looked at a leaking coolant line its either coolant coming out or steam after the level of it has leaked out enough to be below the leak. You will also see evidence of coolant all over down below the leak area.
    Coolant pressurizes itself against the radiator cap up to a certain amount. It wants out. Cap keeps it in. Nothing air about it.
    I can go on but I think we understand air leaks here.
  6. Froxtayle
    We are definitely losing air pressure, so you guys are probably right about it not being the coolant line. Thank you for confirming that no air pressure goes to the coolant hose. We will continue investigating and I will update ASAP
  7. wichris
    wichris Road Train Member
    4,276
    8,602
    Jan 17, 2011
    If it's a DD15 and the air compressor is leaking you can get air pressure in the coolant. Would explain air and coolant loss.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,466
    6,504
    Aug 26, 2014
    Had a FLD? with a air controled water valve in the sleeper. It was putting pressure in the coolant and swelling all the hoses.
    Rideandrepair Thanks this.
  9. FreightyAK
    FreightyAK Light Load Member
    51
    42
    Aug 7, 2018
    AK
    I had a cummins that had a bad aircompressor head gasket. It would pressurize the cooling system. So yes air can pressurize cooling system for those who said it can't. Im not saying thats your problem but its something to think about
    BoxCarKidd and Rideandrepair Thank this.
  10. Rideandrepair
    17,321
    56,197
    Aug 8, 2015
    If I remember port side is Drivers side, Starboard would be Passengers side. And a nautical mile is? And a knot equals? Lol. Anyway maybe it’s the coolant line to compressor. 1 in /1 out.
  11. Rideandrepair
    17,321
    56,197
    Aug 8, 2015
    That’s often overlooked, My 92 WS had one on the firewall also for cab. Bunk valve went bad, turn key off, with radiator cap off, it shot coolant 15’ into the air, like a volcano. Lol, Luckily figured it out, before I let them pull the head. Everyone said I needed an OH. My 99 Freightliner had one on bunk only. Current 2000 doesn’t, Thank God. It was a bad design, cause of many unnecessary repairs.
    BoxCarKidd Thanks this.
